F55/F56 Has anyone installed a larger Tach?
Old Apr 17, 2019 | 10:46 AM
emans's Avatar
emans
Hi all,
I just got my F56 JCW recently and I must say the tach on it is tiny. Anyone know of any tach that can be installed easily aftermarket?Thanks!
Old Apr 17, 2019 | 12:06 PM
J_L's Avatar
J_L
I'm planning on adding a sequential shift light. Easier to see without looking at it. Will post results once I'm done. Likely going with something called Chippernut, but the Trac-Pac looks interesting too.
https://www.chippernut.com
https://fastlaneinnovations.com/prod...l-shift-light/
Do you have the HUD? I think there's a track mode or something on there with tach?
Old Apr 17, 2019 | 01:31 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
that Trac-Pac is pretty cool. Ive never seen that before. Where does it connect? I cant tell
Old Apr 17, 2019 | 01:38 PM
J_L's Avatar
J_L
There is a tach wire on the OBD2 harness. Then you also need to get a positive / ignition, and ground somewhere of course. Oh, but I think my biggest issue is, if I recall, it doesn't auto-dim with headlights on. The Chippernut and some others have another wire that goes to your lights switch for that.
Old Apr 17, 2019 | 02:26 PM
02fanatic's Avatar
02fanatic
The tach is probably the weakest design feature on the F56 hands down. I only have the radio (my preference) and there’s room for a speedo in the center pod where the speedo should be on a MINI! There should be a tach straight behind the steering wheel complete with the gear change indicator, etc. My bet is MINI was pushing the steptronic auto transmission from the get go, so having a tach in the forefront wasn’t even a consideration! Bad move! I rarely even look at mine, shifting by ear like in the old days! I might add a Sun Tach on the top of the dash like in the old days as well! LOL!
One other solution is to set the circumferential light on the center pod to match the tachometer revs, which I did do & it helps but not as good as a tach dial straight ahead. Of course you need to have the JCW pod to do this.
Old Apr 17, 2019 | 07:08 PM
an3ony's Avatar
an3ony
I'd love to be able to swap the tach and speedo. Also, i despise the fuel gauge. I know its archaic but I like the traditional face indicator
Old Apr 18, 2019 | 03:08 AM
02fanatic's Avatar
02fanatic
At least the Tach & Speedo aren’t digital gauges!
duvinclunk
Tires, Wheels, & Brakes
Aug 29, 2011 04:58 PM
HAL9000
Oct 11, 2006 03:40 PM
UKSUV
Electrical
May 8, 2006 04:35 AM
The MINITOR
Nov 6, 2005 07:31 PM
