F55/F56 FMIC Upgrade and More
Old Apr 17, 2018 | 06:51 AM
Scottkenny's Avatar
Scottkenny
Last weekend I upgraded my FMIC to a Forge Intercooler, installed a Dinan Elite Power Module, installed an AWE Carbon Fiber Intake, installed a NM Catless Exhaust system, installed Forge Chassis braces, installed Powerflex engine mount, installed NM short shifter on my 2016 F56 JCW. There were a lot of discrepancies between the instructions provided by Forge and the setup of the car. Once we worked through them the IC was installed and seemed to work well. This morning it seems that I can only keep and maintain boost at ..5BAR or around 8PSI. Has anyone seen this. I haven't had a chance to get her back up on the lift, I am suspecting a loose FMIC hose most likely on the return side and not the charge side of the FMIC. This also started after I filled up with 100 Octane.
Thought?
Old Apr 17, 2018 | 07:16 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Man, you threw a lot on at once didnt you!
It could be the IC or the Elite. Did you check all the connections for that? Its weird that you said it worked fine then the next day you started getting thise issues
Old Apr 17, 2018 | 07:29 AM
vetsvette's Avatar
vetsvette
Moderator
When they replaced my engine I got a CEL and reduced power on the trip home. When I went back to the dealer they found a loose hose/pipe on the intake system. I think you would get a CEL if it is an I/C hose. I would check the Dinan hookup to, although I can't see a connector coming loosed if it was properly installed.
Old Apr 17, 2018 | 12:54 PM
Scottkenny's Avatar
Scottkenny
I didn't mention that part. It was fine for about 200 miles. Once I put 100 Octane in in Thursday I didn't drive much until Sunday. This morning on my way to work the boost gauge caught my eye. The weird part is its different in gears 1 and 2 which makes me think its a tune issue so I might have hit the boost cutout limit. In gear 1 and to its .5 bar in gears 3 and 4 its .7 bar. It holds boost pretty steady between 2500RMP until 4500 RPM.
Old Apr 17, 2018 | 03:08 PM
Andrew Park's Avatar
Andrew Park
Most likely your intercooler hose. When I installed my Wagner IC, I got the same problem. Those hoses have to be pushed in all the way or else it won't seat and it will cause a leak. It's a pain since the hoses are super tight but doing so fixed my issues.
Old Apr 17, 2018 | 05:07 PM
Scottkenny's Avatar
Scottkenny
Well it’s not the tune. All wires connected and ecu reset still same boost levels. Guess that narrows it down to the intercooler hoses.
JIM_GRAHAM
Feb 26, 2016 11:45 AM
Hujan
R60/61 Cooper S Drivetrain
108
Nov 30, 2015 01:47 PM
ZK-JCW
Sep 7, 2014 04:03 AM
PinkMiso
Aug 9, 2013 08:19 AM
BostonR56S
Jul 24, 2009 08:21 AM
