F55/F56 Best inexpensive mod you have done? Worst?
Old 09-06-2016, 10:56 AM
ASKtheteach's Avatar
ASKtheteach
ASKtheteach is offline
There are two auto options: the regular auto and the sport auto. The paddle shifters only come with the sport auto. I also have the JCW interior and when you get the sport auto, the shifter is different too. Mine has red stitching on the boot and ****, a red shifter button, and a metal "collar" that runs about three quarters of the length of the shifter from top to bottom.
  #52
Old 09-06-2016, 12:56 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
According to MiniUSA Configurator the paddle shifters are a $250 option.
  #53
Old 09-07-2016, 12:32 AM
MiniF55's Avatar
MiniF55
MiniF55 is offline
GregoryK what suspension are you running, if any. I have coilover KwV3, I'm sure a away bar will help. Just not sure by how much with my current setup. I'm not quite the expert, but I do like to play around the turns and the twisties.
  #54
Old 09-07-2016, 03:07 AM
GregoryK's Avatar
GregoryK
GregoryK is offline
I still have stock suspension. The roads are just too bad. Even my 18" rims have caused some tires to get damaged.
For me it is the way the car "breaks loose" when pushed hard. I want may car to be a neutral as possible. On the stock F56 the front end suffers from (like most FWD cars) understeer. In other words the cars front wants to go straight when you turn the wheel. The heavier rear sway bar will correct this somewhat by causing the back wheels to break loose. This is no mid engine car but the improvement is really noticeable and you feel way more confident pushing the car hard.
If you feel the understeer is a problem then this is a great mod you can do yourself in your driveway. It is also easily adjustable.
Let us know if you decide to go for it and the results.
  #55
Old 09-07-2016, 09:18 AM
N2MINI's Avatar
N2MINI
N2MINI is offline
Joey Modded Headlights- $8 can of Plasti-dip
Stripes/graphics- pretty cheap to unlimited amount
DIY Front Splitter- virtually free with access to CNC machine
Cat-back exhaust- not toooo pricey if you install yourself ( but can be )
Vented A-Panels- can get alittle pricey with paint etc. but looks cool
Rear Sway Bar- best bang for the buck performance wise- $225 or so if you do install
The list can go on. Pic of some of these are in my Gallery on here..
  #56
Old 09-07-2016, 11:12 AM
MiniF55's Avatar
MiniF55
MiniF55 is offline
Joey mod! Mini needs to pay Joey for the inspiration, Lol. Just so happen they now offer black headlight housing. I guess it's nice the mini people listen to the consumer needs.
  #57
Old 09-07-2016, 11:18 AM
N2MINI's Avatar
N2MINI
N2MINI is offline
Have you seen their price compared to the DIY way... It's $500!!!!!!!!! Starts off at $100 till you check the box and then you get a pop-up saying you have to also get the High End option lights which puts you at $500.
  #58
Old 09-07-2016, 11:26 AM
honderpilot's Avatar
honderpilot
honderpilot is offline
I'd love to see pics of your car
  #59
Old 09-07-2016, 11:42 AM
N2MINI's Avatar
N2MINI
N2MINI is offline
Here is a few. DIY Brake ducts vents as well.
Attached Thumbnails Best inexpensive mod you have done? Worst?-help.jpg   Best inexpensive mod you have done? Worst?-new-bumper-001.jpg   Best inexpensive mod you have done? Worst?-1389.jpg
  #60
Old 04-05-2018, 01:58 PM
Cohnhead's Avatar
Cohnhead
Cohnhead is offline
R60 Countryman flat floor mod
Hi! Do you have any pictures of this? Not getting the flat load floor on my 2013 Countryman is my only regret. It sounds like my husband might be able to do the same thing you did.
Originally Posted by bratling
My wife's R60 Countryman came without flat load floor. I bought a used FLF floor panel, got a sheet of ¾" maple ply, cut to fit, including notches for the centering pins and support for the panel. It rests upon existing trim panels in the car, but it would be trivial to add standoff legs if needed.
We left the wood unfinished, but I recently bought speaker fabric to cover a subwoofer I built for my car, and I'm thinking of finding some time to cover the wood and make it blend in.
It was a good use of a couple hours of time to set up.
  #61
Old 04-05-2018, 02:14 PM
vetsvette's Avatar
vetsvette
Moderator
Inexpensive mods...... Hmmm. I'm gonna have to think about that and get back to ya.
  #62
Old 04-07-2018, 11:43 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Sure! Just went digging through my photos. I’ve attached a few to this post. But I’d say this is the most useful for those wishing to pursue this:
Attached Thumbnails Best inexpensive mod you have done? Worst?-5cfe3953-68a1-4025-9eab-4bb8c6822b7d.jpeg   Best inexpensive mod you have done? Worst?-45f7e8fb-c934-4ada-85a5-cea2ad08bcc0.jpeg   Best inexpensive mod you have done? Worst?-fcc36243-885d-40f6-9e22-6881540b627b.jpeg   Best inexpensive mod you have done? Worst?-20e81763-a57d-40b2-bd06-5ec6e6a5db61.jpeg
  #63
Old 04-07-2018, 11:45 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Note that the outside edges are NOT entirely square. I made a cardboard mock-up to get the angles right before I cut any plywood.
  #64
Old 04-12-2018, 06:30 PM
rtowell's Avatar
rtowell
rtowell is offline
What is the source for the spare ... looking for one before MTTS
  #65
Old 04-12-2018, 09:13 PM
vetsvette's Avatar
vetsvette
Moderator
Strange looking tire on that spare.
  #66
Old 04-13-2018, 06:39 PM
Tio Barry's Avatar
Tio Barry
Tio Barry is offline
That is a blow up spare from an early 2000s small Mercedes (5x112) It is 15 inch so if you have anything other than a Cooper you will have to mount the spare on the rear. Also the spare is made for 12mm ball seat lug bolt so you will have to drill out the bolt holes to 9/16s or so. Once this is done the spare will be functional for 50 miles at 50 mph.
  #67
Old 04-13-2018, 06:42 PM
Tio Barry's Avatar
Tio Barry
The standard 14mm bolt will work for the revised blot holes.
  #68
Old 04-14-2018, 03:45 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
what Tio Barry said it is FAR from an “inexpensive mod” but I feel better with this set up for my spouse. Here is some more detailed info on it:
http://www.totalmini.com/forum/39-mi...ver-spare.html
  #69
Old 02-03-2020, 04:05 PM
joemysterio's Avatar
joemysterio
joemysterio is offline
Originally Posted by darex
Shift **** from ICT. Highly-recommended!!
http://www.innovativcar-tech.de/en/m...eneration.html
How much taller is it compared to the stock shift ****? Ever since I installed the CS short shifter and pro clip, my shift **** doesn't stay on anymore as it pops off with the smallest tug.
pwilk20
61
11-14-2020 05:20 PM
02-23-2017 05:27 AM
doomsdaybob
11
09-08-2016 07:00 AM
Thirdfrank
Tires, Wheels, & Brakes
08-28-2016 07:21 PM
KnighTT
08-03-2016 10:02 AM
Quick Reply: F55/F56 Best inexpensive mod you have done? Worst?
