F55/F56 Any problems withe LED lights after lowering?
Old Jul 2, 2016 | 11:27 AM
sootyvrs's Avatar
sootyvrs
In the past when I've lowered previous cars (mostly BMW) the headlights always needed adjusting (dipped beam up or down) which included Xenon lights wheich are suppose to be self levelling..
Has anyone had problems with the LED lights after installing either coilover or lowering springs?
Thanks in advance
Old Jul 2, 2016 | 12:47 PM
vetsvette's Avatar
vetsvette
Moderator
None here.
Old Jul 2, 2016 | 07:59 PM
Antberrie's Avatar
Antberrie
Me neither.
Old Jul 3, 2016 | 08:09 AM
Ti DeZod's Avatar
Ti DeZod
Nope
Old Jul 3, 2016 | 11:37 AM
sootyvrs's Avatar
sootyvrs
Thanks all.. Thant's given me some confidence to get mine lowered
Old Sep 18, 2016 | 12:42 PM
sootyvrs's Avatar
sootyvrs
Thought I'd update this thread as I had my car lowered yesterday and first time to try out the dipped lights in the dark...
I think the rear is slightly more lowered than the front (relative to when it was std. height) and noticed that the dipped beam was higher than it was before... Great that I could now see further than before but had a few on coming traffic flash me too.
Had a look under the hood and behind the light cluster there are 2 white allen key adjusters on each light unit. I adjusted in the inner one and it adjusts up and down.
I turned it one full circle clockwise to lower the beam on both lights which was slightly too low so settled for half a turn in the end... Now dipped beam is perfect.
Not sure what the outer adjuster is for... I did a quick half a turn just to see but it didn't seem to make any difference (perhaps for adaptive lights which I don't have?).
Old Sep 18, 2016 | 03:10 PM
bratling's Avatar
bratling
Super Moderator
If it's like the other headlights I have adjusted, the outer screw adjusts the left-right axis.
Old Sep 19, 2016 | 09:25 AM
hp79's Avatar
hp79
I didn't know we could lower the headlight aim as I read somewhere these are self leveling. I thought I saw that every time I start my car the headlight would aim up and down and then settle. Well good to know that it's adjustable. I always thought the default was a little bit high. I love the LED lights.
Old Sep 19, 2016 | 11:28 AM
WillShootPhotos's Avatar
WillShootPhotos
My guess would be that the adjustment helps set "level" re: the stance of the car, installation variables, etc... then the automatic leveling takes over from from there...
- Will
Jonshungry
Suspension
Feb 26, 2017 09:35 AM
Cmv138
Apr 11, 2016 06:18 AM
dyeLucky
Mar 31, 2016 11:54 AM
808R53
Detailing 101
Mar 18, 2016 04:49 AM
mini4usa
Sep 6, 2002 05:13 AM
