F55/F56 Jack Pad Adapter
Old Sep 15, 2016 | 05:43 AM
  #26
GregoryK's Avatar
GregoryK
I've only used jack stands on the back jack points. These worked perfectly for working on the rear suspension. You jack from the front and the back comes up too. I did not try this but maybe once the backs are jacked if you continue to lift the front it would lift the front opposite side? Then just slide the stand in that way?
Old Sep 15, 2016 | 06:46 AM
  #27
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
remove them, they come off and it's like hitting a hocky puck, lotta tracks do not want them installed
Old Sep 15, 2016 | 06:53 AM
  #28
GregoryK's Avatar
GregoryK
It is interesting that you say that. They are likely designed to work in conjunction with the MINI jack that is barely present in most US and Canadian cars. As there is no spare tire it makes little sense for a car that can be completely customised. A flat jack point would be more valuable for all cars with run flats....and something that would not break off!
Old Sep 15, 2016 | 08:27 AM
  #29
JAB 67's Avatar
JAB 67
If you remove the jacking points, simply get jack pads that are grooved to accommodate the pinch weld.
Old Sep 15, 2016 | 04:20 PM
  #30
jgg5's Avatar
jgg5
convertible has more jack point possiblities
Get the F57 (or R57 or R52) convertible the extra cross bracing provides several hard points suitable for a jack or stands
Amarco Dimayacyac
Jul 16, 2016 08:14 AM
quickcoop
Jul 14, 2016 05:23 PM
takrdown
39
Jul 12, 2016 12:22 PM
fenderpicks
Jun 17, 2016 04:09 PM
krawzdogg
Jun 11, 2016 04:34 AM
