F55/F56 Removing Side Turn Indicators
Old Jun 15, 2016 | 11:45 AM
rphox2003's Avatar
rphox2003
My driver's side turn indicator collects water inside and today at my scheduled maintenance the service rep pointed out that it was cracked. Probably got a hit somehow before I bought the car, so it's not covered under warranty.
He gave me a $100 estimate but said I could get one cheaper off the internet, which is fine by me.
My question - How easy/difficult is it to remove the old one? The videos I've found online only show older models where you slide the whole assembly forward, which you can't do on an F56.
Thanks.
Old Jun 15, 2016 | 02:12 PM
vetsvette's Avatar
vetsvette
Moderator
Very easy. Just hook your fingertips under the bottom edge and lift up and pull out on the bottom to release. Unplug the lamp connector making sure you don't let it fall into the fender. Installation is the reverse. Once you can examine the replacement it's easy to see how it works with the spring clip on top and the two locking tabs on the bottom.
Old Jun 15, 2016 | 09:10 PM
rphox2003's Avatar
rphox2003
Originally Posted by vetsvette
Very easy.
Thanks!
Old Jun 15, 2016 | 09:17 PM
vetsvette's Avatar
vetsvette
Moderator
No problem. I have a set of MCS clear lights that I'm not using, but I'm guessing that since you have a Mini One you're not located in the US.
thinkMINI
Detailing 101
27
Feb 22, 2018 04:06 PM
Thomas J
Mar 26, 2016 07:41 PM
1004ron
Mar 22, 2016 09:39 AM
JWA
Mar 21, 2016 02:57 PM
JWA
Mar 20, 2016 04:30 PM
