F55/F56 Alternative shift knob
Old Jan 18, 2016 | 06:58 AM
  #51
vetsvette's Avatar
vetsvette
Moderator
Glad you got it sorted out. A side note about the Cravenspeed short shifter... It can all be installed while sitting in the drivers seat. No need to lift the car and work under it.
http://www.cravenspeed.com/adjustable-short-shifter/
Old Jan 19, 2016 | 09:33 AM
  #52
darex's Avatar
darex
I read the installation instructions. Not bad. Sounds like removing the armrest and center console are the most time-consuming/tedious part of the installation.
Old Jan 20, 2016 | 11:40 AM
  #53
darex's Avatar
darex
Here's my temporary **** until my ultimate replacement arrives. It's a $20 Autozone special, but oddly, I really kind of like it. I like it MUCH better than the stock ****.
Old Jan 20, 2016 | 11:42 AM
  #54
atlantaorange's Avatar
atlantaorange
that looks surprisingly good for Autozone!
i have always thought that some of the $100 metal ***** are overpriced...
Old Jan 20, 2016 | 03:09 PM
  #55
darex's Avatar
darex
I guess they are! I also kind of enjoy the fact that it's not even etched with the gear numbers.
Downside: freezing cold to the touch, at first. LOL
shift ****
Old Jan 20, 2016 | 03:24 PM
  #56
DAVIDLEERAD's Avatar
DAVIDLEERAD
shift ****
How did you attach it?
Old Jan 20, 2016 | 05:13 PM
  #57
darex's Avatar
darex
It slides right onto the stick (w/o using the included adapters), and locks with three tiny allen screws onto the divot down the shaft of the stick, and those screws are covered by a ring that screws onto the ****.
Old Jan 20, 2016 | 06:09 PM
  #58
DAVIDLEERAD
it slides right onto the stick (w/o using the included adapters), and locks with three tiny allen screws onto the divot down the shaft of the stick, and those screws are covered by a ring that screws onto the ****.
Old Jan 21, 2016 | 06:47 PM
  #59
MidnightF56's Avatar
MidnightF56
How many here had the shifter-gate recall work done, and subsequently successfully removed their shift *****?
I swear, they glued the **** onto the top of the gear lever! They must have!
I know they notoriously require a lot of elbow grease straight up to remove them, but I simply cannot remove the stock ****! I am nearly thinking it's now impossible due to glue. I opened the sunroof, straddled the seats and pulled with all my might, repeatedly: Nothing! WTF!!??
Any tips would be greatly appreciated!!
I had the recall done, and have since replaced my **** with the Cravenspeed one.
Old Jan 22, 2016 | 09:34 AM
  #60
Escoozi's Avatar
Escoozi
Originally Posted by MarcoPolo
the pictures i took when i took mine off. hope it helps in any way...
https://goo.gl/photos/YxnWeTNsQDe6UKjK9
This is super helpful!
What are the benefits to a short shifter? is it easier to shift or is it mostly aesthetic? Thanks.
Old Jan 22, 2016 | 01:37 PM
  #61
MidnightF56
Less travel betweeen gears when you are shifting, or a "shorter throw".
Some kits replace the entire linkage (and can therefore be multi-height adjustable) and some are just simple adapters. Besides differing in the way they achieve the shorter travel, they can differ in the amount of leverage they provide which affects feel.
Old Feb 9, 2016 | 02:26 PM
  #62
darex's Avatar
darex
What do we think of my new shift ****? I love it!!
Old Feb 9, 2016 | 02:38 PM
  #63
Looks great , So you modded the ZHP shift **** ?
https://www.ecstuning.com/Search/SiteSearch/25117896886
Old Feb 9, 2016 | 06:58 PM
  #64
darex's Avatar
darex
Nope. I bought from these people:
INNOVATIVECAR-TECH
They shipped fast, and the quality is excellent -- and it's lighted!
Their shift boot is real leather, unlike MINI's.
I tapped the power from the Sport-Mid-Green socket. It's right there, after all.
I always liked the clean look of VW shifters, and this is reminiscent of them. I think it looks WAY better and more at-home than the OEM shifter.
The only bad thing I can say, if you consider this bad, is that it's lighter than OEM or ZHP, I believe.
Old Feb 9, 2016 | 07:07 PM
  #65
pjsjr13's Avatar
pjsjr13
Interesting
Old Feb 10, 2016 | 06:40 AM
  #66
Yea, looks close to the design. The zhp has some weight to it.
Old Sep 5, 2016 | 05:12 PM
  #67
toyopet's Avatar
toyopet
This could be a good thing. It give you a perfectly good excuse to buy a Cravenspeed short shifter. When you remove the stock shifter you can remove the boot from the bottom and just leave the pesky stock **** attached to the stock shifter. I guarantee you'll like the shifter.
How much shorter in height (not throw) is the Cravenspeed shifter compared to the stock oem shifter?
Old Sep 5, 2016 | 05:23 PM
  #68
vetsvette's Avatar
vetsvette
Moderator
You can adjust it from ~stock height to ~4" shorter. You can tell from the picture that mine's considerably shorter.
Old Sep 5, 2016 | 05:29 PM
  #69
toyopet's Avatar
toyopet
It seems the stock shifter is either too high or too far back. Since I can't move it forward, I will most likely get the Cravenspeed to shorten it. How does the red shift **** match with the stitching? Thanks for your reply!
Old Sep 5, 2016 | 05:36 PM
  #70
vetsvette's Avatar
vetsvette
Moderator
I recommend you order the Pro Retaining Clip at the same time. Much tighter tolerances than the stock clip and makes for smoother shifting. Just remember to lube it good when installing. White lithium grease works well.
http://www.cravenspeed.com/mini-shif...ning-clip-pro/
Old Sep 5, 2016 | 06:19 PM
  #71
GregoryK's Avatar
GregoryK
So this is a straight replacement for the stock clip?
Old Sep 5, 2016 | 06:40 PM
  #72
vetsvette's Avatar
vetsvette
Moderator
Yep.
Old Sep 6, 2016 | 09:10 AM
  #73
Ignoramist's Avatar
Ignoramist
I just tried again, with motorcycle gloves on, the sunroof open and me straddling the lever. Thanks to MINI's glue fix, that **** is not coming off -- EVER! I'm really pissed-off about this! Whatever glue they used, it's permanent!
I must say, when I'm in my car yanking on my ****, I like to stand up in the middle with my head through the open sunroof.
Old Sep 6, 2016 | 01:21 PM
  #74
Yea, its a struggle to get the **** off.
kgelner
R60/R61 Stock Problems/Issues
Aug 13, 2017 05:24 PM
tragedybysyntax
12
Jan 12, 2016 06:52 AM
[My_Mini]
Jan 11, 2016 12:31 PM
banyan
Jan 6, 2016 01:25 PM
techtipz
Jan 4, 2016 10:26 PM
