F55/F56 Missing floor jack in trunk
Old Dec 28, 2015 | 06:05 AM
Albert Godoy's Avatar
Albert Godoy
Hi ppl,
So I am on Mini number 3 and had a question. I just traded in my 2015 Cooper 5 door on a new 2015 Cooper S 5 door.
After cleaning it out from driving for the holidays, I decided to peek at the emergency essentials and it looks like I'm missing my "jack".
I know I have no spare and I am on run flats but doesn't it still have a jack?
Please confirm before I go asking WTF at my dealers lot.
Thanks.
Old Dec 28, 2015 | 06:48 AM
USA-RET's Avatar
USA-RET
My F56 w/ run flats didn't have a jack either. I assume their logic being w/ run flats you drive to get tire repaired or replaced. Roadside assistance being included also essentially eliminates the need for one also.
I too was surprised to find mine missing but after thinking about it, I came to the same conclusion they did.
Old Dec 28, 2015 | 07:31 AM
Sailorlite's Avatar
Sailorlite
No jack for mine either ('15 MCS). I made my situation somewhat riskier by immediately exchanging the standard runflats for good conventional tires - but I added a Slime pump and puncture kit at least. I already had one flat tire (slow leak) and simply drove to the tire store for a good free repair job - that would have been far trickier with a runflat tire.
TWISTER's Avatar
TWISTER
Whats a trunk? after 3 MINIs?
Old Dec 28, 2015 | 08:19 AM
Albert Godoy
Great!
Thanks everyone for your prompt responses. I was debating on driving down to the store today if no one replied but that saves me a trip.
Old Dec 28, 2015 | 11:19 AM
Funny seen a 2014 f56 with the jack. Must be a change, 71121501930 * edit was thinking R56 .
https://www.ecstuning.com/Search/SiteSearch/71121501930/ES184727/
Also the above set up looks like for the mobility system set up minus the mobility kit .
http://www.realoem.com/bmw/enUS/show...diagId=71_0786
VS
Jack set Up
http://www.realoem.com/bmw/enUS/show...diagId=71_0788
Old Dec 28, 2015 | 11:22 AM
siriuszero's Avatar
siriuszero
F5x Cooper S MINIs don't come with a jack or tire iron - just the screwdriver and the tow hook. You can, however, order the bits from the Cooper models and they will fit in that compartment if you want them handy.
Old Dec 28, 2015 | 11:25 AM
Albert Godoy
I know for a fact I had that same jack in my non S with spare tire. Going to call my sales guy just to make sure. He texted me this weekend to make sure I gave him all "10's" on the survey Mini usually sends out. I am sure he will make it right if its not.
Old Dec 28, 2015 | 11:49 AM
Albert Godoy
Like I said, this is my first S so its always been black on my other minis Do any of y'all know if its normal for this light to get moisture behind it? Both of them are doing it.
Old Dec 28, 2015 | 11:51 AM
Not that much. Must have been hit with a high pressure hose wash or the bulb socket seal needs re-seated and turned.
Old Dec 28, 2015 | 11:53 AM
Albert Godoy
No high pressure washing. Just been raining here in GA.
Old Dec 28, 2015 | 01:41 PM
srmitch2's Avatar
srmitch2
VS
Jack set Up
Correct. "S" with no Jack kit. A flat repair kit is optional, and a Tire change kit is also available for purchase.
Old Dec 29, 2015 | 11:50 AM
watchluvr4ever's Avatar
watchluvr4ever
My F56 non S with run flats has the jack.
Old Jan 1, 2016 | 01:48 PM
MasterYoda's Avatar
MasterYoda
The non S has room for a spare, the S does not.
Old Jan 2, 2016 | 08:51 AM
Sailorlite's Avatar
Sailorlite
Roadside Assistance finds non-runflat tire?
With only 200 miles on my MCS I replaced the OE runflat tires with good conventional Michelins. So what happens if I have to call MINI Roadside Assistance for a flat tire? With runflats, RA would be inclined to tow me to a dealer for an expensive replacement tire - but that wouldn't be necessary with conventional tires. Will they care that I don't have the factory runflats and now have a different type of tire instead? Have I jeopardized that part of the RA benefit?
Old Jan 2, 2016 | 10:10 AM
siriuszero's Avatar
siriuszero
Shouldn't make any difference if you get a flat - they have no idea what tires are standard or not. Though if you did have the RFs, they wouldn't need to tow you anyway!
Old Jan 2, 2016 | 10:14 AM
Eurothrasher's Avatar
Eurothrasher
Depends
I have heard in some cases where that assistance was charged back to the customer when car no longer had runflats on....
For those folks that have a MINI with the original factory Pirelli Run Flat Tires, they automatically have Pirelly Road Hazzard warranty thru Pirelli.
MINI would take care of you for the tow to a dealer if needed, and Pirelli willl pick up the cost of new tire ( pro rated ) MINI Service Dept has to billl out new Pirelli tire, take photo of the old tire, take prod # off of tire, and if possible take photo of the object in tire, and then measure tread depth for a claim as the customers cost for new tire is pro rated. Then coders for processing the claim at the dealer need only process it same as any other MINI warranty.....Have seen this done several times in the recent past.
Old Jan 2, 2016 | 01:22 PM
02fanatic's Avatar
02fanatic
I'm not very close to my MINI dealer, so in the unfortunate event I ever need to replace one of my Pirelli P7 runflats, I'll likely take care of it on my own....it's not that hard changing a wheel & tire (as long as I have a spare available, either with me or at home). I'm not very trusting of any tow truck driver other than my personal mechanic....something always goes wrong it seems. When you have a beater that you don't worry so much about there's usually no issues when towing, but having a new MINI and having it towed, bad luck seems to always raise its ugly head...so why take the chance? I won't go there unless I'm truly stranded!
Old Jan 4, 2016 | 12:17 PM
Had Pirelli send me new tires once because of a road hazard. They took care of it. But You have to do a claim and have the tire info and everything. Can of fix a flat got me home.
Old Jan 4, 2016 | 12:57 PM
DaGriz's Avatar
DaGriz
I have run flats on my R52. Ordered a space saver spare. Almost fits in the bonnet (never said that before) but looks like if I let some air out of the space saver it might and I have a pump and fix a flat in my kit to reinflate. I would only take on long trip if I did at all.
Old Jan 5, 2016 | 08:11 AM
vetsvette's Avatar
vetsvette
Moderator
Originally Posted by DaGriz
I have run flats on my R52. Ordered a space saver spare. Almost fits in the boot (never said that before) but looks like if I let some air out of the space saver it might and I have a pump and fix a flat in my kit to reinflate. I would only take on long trip if I did at all.
Fixed it for you.
Old Jan 5, 2016 | 08:34 AM
DaGriz's Avatar
DaGriz
Originally Posted by vetsvette
Fixed it for you.
The mind's a terrible thing. That would be a tight fit.
WarEagle
R55 :: Clubman Talk (2008+)
17
Feb 16, 2016 10:39 AM
Dec 7, 2015 02:32 PM
Dec 6, 2015 08:44 AM
Suspension Products
Dec 4, 2015 04:51 PM
raata
Nov 29, 2015 03:16 PM
