F55/F56 Side Scuttle install
Old Dec 2, 2015 | 06:06 AM
USA-RET's Avatar
USA-RET
Just curious, how much double sided 3M tape do/did you use to install a side scuttles. I've seen one thread with an "Overboard approach", but would prefer to be a minimalist when using the double sided tape.
3M makes a double sided molding tape which I thought would be a good choice.
                     3M 03609 Scotch-Mount 1/2" x 5' Molding Tape                   3M 03609 Scotch-Mount 1/2" x 5' Molding Tape
I was thinking of using a 2-3" piece of this tape in each of the four sides to hold the scuttle in place. Since the scuttle is light weight and remains stationary on the side of the car. I figured you wouldn't need a large amount of tape to hold it in place. Additionally, if it ever had to be removed, Smaller pieces of tape would be much easier to deal with.
Thoughts? Suggestions? Condemnations?
Old Dec 2, 2015 | 06:53 AM
You remember this :
https://www.northamericanmotoring.co...d-removal.html
I would measure the tape thickness , then measure the depth of the back of the scuttle to the body. Then run it around the boarder, press and hold and make sure its secure . You don't want one flying off at autobahn speeds
Old Dec 2, 2015 | 08:56 AM
USA-RET's Avatar
USA-RET
Actually yes, I do remember.
With the scuttle weight (and it fixed position), was thinking full strip on leading edge and smaller strips on each other edge should be sufficient.
Does the side marker light also aid in attachment of scuttle to car?
Old Dec 2, 2015 | 10:40 AM
vetsvette's Avatar
vetsvette
Moderator
Nope. The Light attaches to the new scuttle. Of course the wire might hold for a little while if it flies of at 70mph.
Black-eyed-Purple-Mini S
Dec 19, 2015 04:49 PM
USA-RET
Dec 19, 2015 07:32 AM
MiniSuperCooper
Dec 11, 2015 10:08 AM
aviaator
Nov 26, 2015 06:47 AM
InDaClubMan
Nov 14, 2015 02:53 AM
