F55/F56 Question for Click and Drive Owners Please
Old Oct 30, 2015 | 12:39 PM
bctf1's Avatar
bctf1
Since the wiring harness for the Click and Drive only provides power to the phone, I want to know if the harness can be removed from the cradle without having to cut the cable. In other words, does the cable connect to the cradle with a connector?
I would prefer to run a flat black lightning cable running from the console USB port to my iPhone 5s for both power and data and route the cable tucked into the dash. However, if down the road I wanted to mount a Garmin GPS, I would want to be able to use the included wiring harness for power.
Thanks for your responses.
Old Oct 30, 2015 | 01:25 PM
hammerhands's Avatar
hammerhands
There is a USB cable running from the Click & Drive unit to a car-lighter USB power adapter. The car-lighter adapter is connected to a lighter socket dongle that has wires that run to the Body Dommain Controller (fuse panel in the footwell wall). All of this is zip-tied together.
It should be possible to run that USB cable to the USB port instead, and use a 6" Lightning cable to plug the iPhone into the Click & Drive. This assumes that all four wires are soldered.
See pictures and the installation PDF, if you look closely you will see the end of the USB cable in a bracket that is zip-tied to the adapter and the dongle.
https://www.northamericanmotoring.co...lick-drive.pdf
Here you can see where the little cable plugs into the Click & Drive body's USB port.
It's all much sexier to run Bluetooth. I'm running a white lightning cable from my iPod Touch because I don't have Bluetooth Audio, and the USB port on the Click & Drive has another cable charging the Bluetooth speaker I use at work. It's a bit of a mess!
Old Oct 30, 2015 | 01:28 PM
Parrothead2488's Avatar
Parrothead2488
The Click and Drive cable is a USB end and can be wired to dash USB then it will power the USB port on Click and Drive. Charge your Iphone and use the multimedia option on radio. If you use a flat black cable and run it along dash looks awesome.
Good luck!!!
Old Oct 30, 2015 | 02:49 PM
bctf1's Avatar
bctf1
Thanks Hammerhands for your reply and pics. I am finally able to see where the harness cable enters the cradle. The only part of your reply that I am not understanding is where you said "This assumes that all four wires are soldered," please clarify.
It looks to me that you are right. I should be able to get both power and data to my iPhone by connecting the cradle's USB cable directly to the console USB port and then connecting a lightening cable from the phone to the cradle USB port. I wonder how long the USB cable portion of the wiring harness might be and if it is long enough to be tucked into the dash and routed to the console USB port?
Old Oct 30, 2015 | 03:41 PM
hammerhands
I meant that all four wires of the USB cable should connected through to the USB port. It is possible that they only have the power connected.
I recall the cable being long enough.
Old Oct 30, 2015 | 08:06 PM
bctf1's Avatar
bctf1
It looks like the 2 torx screws on the cradle are for mounting it to the instrument cluster. If there is a way to get inside the cradle and see the wiring connections for the USB connector I could confirm how many wires are soldered. Would you assume that if only 1 wire (power) is soldered that the remaining 3 wires could be soldered as well? This is far from my area of expertise.
I've seen the linked installation pdf and read thru it several times. The electrical diagrams are unintelligible to me. If 1 wire is power, 1 wire might be data?, what would the other 2 wires do?
I really appreciate your comments.
Old Oct 31, 2015 | 04:19 AM
hammerhands
It uses two wires for power 5V+ & GND, and two [or maybe 3?] wires for data. I suspect all the wires are soldered. You just need to plug some device through it and see if it works to find out, I don't remember trying this but I'm somewhat convinced that I did because I was curious. There is no obvious way to open the body, but I'm sure it can be done.
Old Oct 31, 2015 | 09:07 AM
bctf1's Avatar
bctf1
Hammerhands, you are remarkably generous and helpful. Thank you so much for your effort.
R55&R60_N18
Feb 17, 2016 08:18 AM
Niccolo_Machiavelli
Jan 26, 2016 11:45 AM
daonlyillwiz
Nov 30, 2015 08:51 AM
Yazon
Oct 27, 2015 09:05 PM
Earthfriend
Tires, Wheels, & Brakes
Oct 27, 2015 12:30 AM
