F55/F56 Question about smaller wheel/tire size for a F56 4-door MCS
Old Aug 20, 2015 | 06:07 PM
col127's Avatar
col127
Hey All,
I recently switched my car to a 2015 MCS, 4-door. I'm wondering if I could use the snow tires from my previous car on the MINI when it comes to winter? There's a lot of life left on them and it'd be great if I could...
The size is 175/65/R15. It's a set of Michelin X-ICE2 tires on steel wheels. Wheels have a bolt pattern of 4-100, 4.5 backspacing, size: 15x6
I don't know much about tires and wheels but I do know you can 'downsize' for winter, but that's about it. Thanks for the help!
Old Aug 20, 2015 | 07:16 PM
Ryephile's Avatar
Ryephile
That's a Yaris/Prius C or MINI 15" size tire. The rolling diameter is about right, but that's about where it ends. Double check the load capacity is acceptable.
Also, the F55 [4-door version of the F56] has 5x112 bolt pattern, so for sure the wheels won't fit. I'd also be wary of a 15" wheel fitting over the Cooper S's larger brakes.
IMO a better sure-thing winter solution would be a factory F55 or F56 16" wheel with a 195/55-16 winter tire. Unless you live in literally in the Arctic, you don't need to go more than a "minus 1" for your winter setup.
Old Aug 20, 2015 | 07:23 PM
col127's Avatar
col127
My former car was a Prius C...
So do 15" tires work at all on the MCS? My MCS currently has a 205/45/R17 wheel on it.
Could I get a 175/65/R15 wheel for the MCS with the right bolt pattern? Would that work? I don't know how this stuff works :P
Old Aug 21, 2015 | 08:41 AM
MINIAC's Avatar
MINIAC
I doubt you'll find a 15" wheel to clear the front brakes on the Cooper S ... Tire Rack doesn't list any.
Old Aug 21, 2015 | 02:11 PM
Smallest is 16" on the S , dont think a 15" will clear the fronts. Also you need 5x112 66.5CB . We have all the sizes and ET listed for the S.
http://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Wheels/OEM_Alloys/
massmini03
Aug 12, 2015 11:19 AM
wind715
Aug 11, 2015 07:56 AM
nomar116
Aug 10, 2015 11:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
