F55/F56 F56 tail light difference
Old Oct 22, 2015 | 11:07 AM
  #26
TheBigNewt's Avatar
TheBigNewt
I like that LED ring around the tail light thingy. The weird thing is that the driver/owner of the car never gets to see the cool LED lights on their cars. I saw one on an Audi yesterday, DTRs were white, cool pattern, and the blinking turn signal light turned amber color on that side. Looked great but the driver can't see it.
Old Oct 22, 2015 | 02:01 PM
  #27
MES11's Avatar
MES11
Yep. The ring is LED. other are standard bulbs, figured with the LED package all would be LED.
The ring on the headlights are LED. The ring on the tail lights are not.
Old Oct 22, 2015 | 02:05 PM
  #28
Its led I have seen it.
Old Oct 22, 2015 | 06:40 PM
  #29
cub4bearindiana's Avatar
cub4bearindiana
sooooo if I put LED bulb in tail lights.. would it work? or am I going get this goofy error code with burnt bulb?
Old Oct 23, 2015 | 05:07 AM
  #30
MES11's Avatar
MES11
Pull out the lights and then tell me it's an LED.
Old Oct 23, 2015 | 06:00 AM
  #31
Bulbs for the upper and lower ( brake) behind the led ring , plus the center (turn)), back up light has a bulb. Now look at the green board, its for the LED , for the ring. This is what I heard from MINIUSA when I was at the launch party ? Unless things changed ? 63217297511 & 63217297512
https://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Lighting/Tail_Lights/
Old Oct 23, 2015 | 08:04 AM
  #32
LordWinslow's Avatar
LordWinslow
Do you folks stock the Euro version of the tail light with the Orange Blinker?
Old Oct 23, 2015 | 08:37 AM
  #33
We can get them it will take a short time to some in from Germany. I will post it up.
Old Oct 23, 2015 | 08:39 AM
  #34
LordWinslow
Sweet, how much for a set?
Old Oct 23, 2015 | 10:43 AM
  #35
They will be added to the site soon with price.
Old Oct 24, 2015 | 11:01 AM
  #36
siriuszero's Avatar
siriuszero
The accent "ring" light is LED, the turn signals, reverse, and brake lights are incandescent. Pull out all the bulbs and the accent ring will remain let because it is part of the tail light assembly. Most BMW tail lights are similar. LED accents, but normal incandescent bulbs for turn/brake/reverse lights.
If you replaced the incandescent bulbs with LED bulbs, you would get an error and "hyper-flashing" - the bulbs will flicker for about 5 seconds when you turn the car on. This can be fixed with coding via ESYS though. All my exterior bulbs are LED replacements.
Old Oct 24, 2015 | 12:31 PM
  #37
LordWinslow
[QUOTE=siriuszero;
If you replaced the incandescent bulbs with LED bulbs, you would get an error and "hyper-flashing" - the bulbs will flicker for about 5 seconds when you turn the car on. This can be fixed with coding via ESYS though. All my exterior bulbs are LED replacements.[/QUOTE]
Nice! Do you have to turn down the sensitivity on the LED's? I am going to add the rear fogs and make some changes to my setup, would like to know what you did to clear out any errors you may get due to LEDs.
Old Oct 24, 2015 | 01:53 PM
  #38
siriuszero's Avatar
siriuszero
No need for resistors or anything - In ESYS you have to turn off the cold and warm bulb checks which will eliminate "bulb out" warnings, then there is a parameter that lets you classify your bulbs as LED that should eliminate "hyperflashing" or flickering.
I have to dig up what the settings are and I'll post em
Old Oct 24, 2015 | 05:49 PM
  #39
MES11's Avatar
MES11
If you pull out the bulb housing and then press the brake, only the incandescent bulbs light up. There are no LED lights in my tail lights.
Old Oct 24, 2015 | 06:38 PM
  #40
LordWinslow
They are part of the housing, the LED ring. The rest of the bulbs are normal ones, what siriuszero was talking about was replacing his normal bulbs with LED ones and the problems with that.
Old Oct 25, 2015 | 05:18 AM
  #41
DarkBlue15MCS's Avatar
DarkBlue15MCS
No need for resistors or anything - In ESYS you have to turn off the cold and warm bulb checks which will eliminate "bulb out" warnings, then there is a parameter that lets you classify your bulbs as LED that should eliminate "hyperflashing" or flickering. I have to dig up what the settings are and I'll post em
Do you have a link to the bulbs you are using?
Old Oct 25, 2015 | 12:17 PM
  #42
siriuszero's Avatar
siriuszero
I don't...I got them several years ago for my Countryman and transplanted them when I got my F55.
I think I got them at superbrightleds.com and got the brightest ones I could find. They are 1157 bulbs I believe.
Old Oct 25, 2015 | 12:24 PM
  #43
DarkBlue15MCS
I don't...I got them several years ago for my Countryman and transplanted them when I got my F55. I think I got them at superbrightleds.com and got the brightest ones I could find. They are 1157 bulbs I believe.
Thanks. I'll check them out
Old Oct 26, 2015 | 08:18 AM
  #44
MES11's Avatar
MES11
The "LED ring" is just a light diffuser and not really a "light emitting diode".
Old Oct 26, 2015 | 08:44 AM
  #45
DarkBlue15MCS
If you look at the picture ECS posted that green circuit board has two very small LEDs that shine light into the diffuser.
Old Oct 26, 2015 | 01:24 PM
  #46
Euro F56 / F55 tail lights linked : 63217297433 & 63217297434
63217297413 & 63217297414
Old Oct 26, 2015 | 01:42 PM
  #47
LordWinslow
Sweet Thank you, I will have no more money if I keep looking at your site!
Old Oct 26, 2015 | 01:55 PM
  #48
vetsvette's Avatar
vetsvette
Moderator
Almost a $50 difference in price from right to left side in the Euro LED lights. Odd.
Old Oct 26, 2015 | 01:59 PM
  #49
Bug on our site. Its fixed now. Thanks
Old Oct 26, 2015 | 04:21 PM
  #50
vetsvette's Avatar
vetsvette
Moderator
Back in May I paid you guys $235 for LED tail lights for my R56. What makes these worth almost $400? It can't just be the size, otherwise the LED Tails for my Suburban would have cost a heck of a lot more than $150. Just curious, because at these prices I'm not even considering a set.
