F55/F56 Wheel bolts or studs?
Old Jan 20, 2015 | 11:15 AM
ftloose's Avatar
ftloose
Just installed a set of 15mm spacers on the rear with longer bolts. Now I've discovered some guys are replacing the bolts with studs. The ease of wheel installation is obvious. But other than that are there any advantages to going to studs instead of bolts?
Old Jan 20, 2015 | 11:59 AM
pgrizard's Avatar
pgrizard
Easy off/on and to accommodate spacers. If you aren't frustrated trying to line up the bolts then its probably not time for studs yet. Dont get cheap ones, they break. Use high heat thread lock on them and if you need to remove them use a torch to heat them up and soften the thread lock.
SosoMINI
Nov 22, 2015 03:17 PM
MINI VINI
Oct 13, 2015 08:57 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
col127
Aug 21, 2015 02:11 PM
minipopkart
Aug 9, 2015 12:13 PM
