F55/F56 MINI B38 3-banger Dyno Test
Old Nov 12, 2014 | 11:23 AM
Terry @ BMS's Avatar
Terry @ BMS
Hey guys,
How that we know how to get the cars in dyno mode we were finally able to get a B38 strapped down for a little testing.
The car managed a best of 138whp stock and 157whp using the BMS Stage1. Overall pretty solid gains. The car had a full tank of gas and the owner wasn't sure if it was 89 octane or 91 octane. So definitely expect a little more power if using say 93 octane.
Attached Thumbnails MINI B38 3-banger Dyno Test-b38.jpg   MINI B38 3-banger Dyno Test-bms_b38_stage1.jpg
Old Nov 12, 2014 | 01:28 PM
Crimguy's Avatar
Crimguy
Very nice. Is the stage one for the B38 also considered beta at this time?
Old Nov 12, 2014 | 01:33 PM
TheBigNewt's Avatar
TheBigNewt
That's the exact same gain that other person posted last week.
Old Nov 12, 2014 | 02:38 PM
ThumperMCS's Avatar
ThumperMCS
Because its the same car and graph....
Old Nov 12, 2014 | 02:43 PM
Terry @ BMS
Yes we've still got the x38 MINI tunes as BETA since they are still so new.
Old Nov 12, 2014 | 08:24 PM
Danger Dan's Avatar
Danger Dan
im ready to see some dyno testing on the stage 1 on the MCS!
Old Nov 13, 2014 | 02:56 AM
N2MINI's Avatar
N2MINI
Nice gains, but what is the engine rated at to start with. I keep reading that it only has 134 HP and that is usually not all getting to the ground..
Old Nov 13, 2014 | 07:08 AM
r33's Avatar
r33
It says on the dyno sheet that the base hp is 136hp.
Old Nov 13, 2014 | 08:03 AM
erikquick's Avatar
erikquick
Looks promising! Was this in Normal mode? Sport mode? Does it matter?
Old Nov 13, 2014 | 08:11 AM
Angib's Avatar
Angib
For comparison, here are the standard power/torque 'curves' for the Yurpeen version, from www.automobile-catalog.com
Old Nov 13, 2014 | 08:36 AM
N2MINI's Avatar
N2MINI
I can read that they have a baseline of 136 BUT that is what the car claims from the factory and you will not get that HP to the ground/dyno pull as you have drivetrain loss, or atleast that is how it has worked in all the other Gen Models of MINI..2002 to present..
Old Nov 13, 2014 | 08:50 AM
r33's Avatar
r33
I got you.
But that dyno sheet is based on actual pull with and without Burger Tuning Stage 1 tuning.
Also keep in mind that it will be hard to replicate the same exact result everytime since there are too many variable that we can't control (such as; air temp, humidity, gas quality, elevation, etc).
Old Nov 13, 2014 | 08:56 AM
N2MINI's Avatar
N2MINI
I don't know how to run a dyno but have read for years that it can be manipulated to read high or low. NOW I'm not saying they did this I'm just asking how did the car read the same HP that it is rated at from the factory. I've never seen it done before with any make or model car... regardless of how the dyno is set up their gain is still their gain which is what they are trying to show here.. as long as all the pulls were done with the same dyno settings..
Old Nov 13, 2014 | 10:19 AM
ThumperMCS's Avatar
ThumperMCS
They're probably under rated from the factory...BMW is notorious for it.
Stock R56 JCW's routinely put out close to their rated bhp numbers...at the wheels. Even Cooper S R56's will put out around 190's ft-lbs to the wheels.
Old Nov 13, 2014 | 03:39 PM
Terry @ BMS
Most turbo BMWs we've tested dyno at the wheels close to what BMW rates them at the crank. Our 2014 M5 did 540whp, our 2015 M3 did 430whp, 2014 435 290whp, 2013 MINI-S 190whp, etc.
Old Nov 14, 2014 | 10:49 AM
gtmotor's Avatar
gtmotor
This.
BMW publishes numbers differently compared to other manufacturers since their turbo engines started coming out about 8 years ago.
I can assure you Terry isn't tweaking the numbers to sell more of his tunes. He has a really solid reputation in the BMW community.
Old Nov 14, 2014 | 11:08 AM
N2MINI's Avatar
N2MINI
I haven't seen any of the newer MINIs dyno-ed but the 1st Gen and early 2nd Gen cars weren't that way.. nice that things have changed.
Old Nov 14, 2014 | 11:11 AM
gtmotor's Avatar
gtmotor
Mini didn't use a proper BMW engine until just recently (2014) in the F56. I believe the R53 used an variant of a Chrysler engine and the R56 used a co-developed Peugeot power plant.
Moving to a true BMW turbo engine is what sold me on the 3rd gen!
*edit* It's amazing what you can find in a 2 minute search on the Internet...
http://en.wikipedia.org/wiki/Tritec_engine (1st gen R53)
http://en.wikipedia.org/wiki/Prince_engine (2nd gen R56)
Old Nov 14, 2014 | 12:27 PM
N2MINI's Avatar
N2MINI
yeah but BMW still had control of things even if they didn't make all the parts and pieces in house..
johntotah94
Oct 19, 2015 02:20 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
atenzany62
Aug 9, 2015 05:54 PM
sungjk
Aug 5, 2015 08:23 PM
