base vs S: brake and wheel size
Subscribe
Sep 29, 2014 | 08:24 AM
hi everyone,
Does the Cooper S have the same size brakes as the base Cooper?
as in can i put 15" snow tires and wheels on my S this winter?
thanks!
greg
Reply 0
Sep 29, 2014 | 09:38 AM
Greg,
The front disks on the Cooper are 10.0". The front disks on the Cooper S are 10.4". The Cooper's basic rim is 15", and the S model has a 16" basic size.
Check with the tire gurus (Tire Rack, etc.) and I am sure you will find that the larger S brakes will not allow the fitment of 15" rims on the S model Hardtop.
Motor on...
Reply 0
Sep 29, 2014 | 11:09 AM
I run 15" track rims on wildwood BBK.. the main issue was the rotor touching the front face of the caliper and i run spacers.. no issue with the rotor edge touching.
Reply 0
Sep 29, 2014 | 12:36 PM
Quote: The front disks on the Cooper are 10.0". The front disks on the Cooper S are 10.4".
That would make them smaller than on the R56 (280mm and 294mm)
Reply 0
Sep 29, 2014 | 01:43 PM
Quote: I run 15" track rims on wildwood BBK.. the main issue was the rotor touching the front face of the caliper and i run spacers.. no issue with the rotor edge touching.
on an F56? didn't know wilwood had a kit already...
Reply 0
Sep 29, 2014 | 03:50 PM
Quote: That would make them smaller than on the R56 (280mm and 294mm)
At my age I should remember to wear my glasses when reading the small print! The correct front disk diameters are Cooper 11.0", Cooper S 11.6". This corrected info is from the MINIUSA web site.
Reply 0
Sep 29, 2014 | 04:30 PM
Quote: At my age I should remember to wear my glasses when reading the small print! The correct front disk diameters are Cooper 11.0", Cooper S 11.6".
That would make them the same size as on the R56
Reply 0
Sep 29, 2014 | 05:25 PM
It's S and non-S. "Base" is not a model. It refers to ANY MINIs with no options.
Reply 0
Sep 30, 2014 | 06:24 AM
Sadly, unlike the R56, the F56 has different part numbers for the Cooper caliper and the S caliper. On the R56 the same caliper was used, so it was easy to switch from Cooper 11.0"/280mm discs to S 11.6"/294mm discs.
Reply 0
Sep 30, 2014 | 07:09 AM
Quote: It's S and non-S. "Base" is not a model. It refers to ANY MINIs with no options.
I'm going with 3-cylinder, but everyone knows what they mean by base.
Reply 1
Subscribe
