F55/F56 Looked into Retrofitting Rear Fogs
Old Jan 18, 2015 | 07:48 PM
  #26
hp79's Avatar
hp79
Originally Posted by spacecadet
As I just posted in the coding thread, you need to do the following - not just buying the switch, but also using e-sys to enable the feature in the body domain controller (BDC)
First, purchase the version of the light switch for your car that includes the rear fog switch and fit it.
Then, the following coding is required to make them work,
1) add option 5AA rear fogs to the VO (vehicle order)
then in the BDC, code the following :-
2) 3068, NSL_Verbaut = Verbaut
(This enables the BDC to sense the switch, if you just code this and try the lights, it just activates the symbol on the instrument cluster but does nothing else)
3)
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = nebelschlusslicht
These options enable the correct outputs on the BDC to activate the lights. ....
Do you think adding the VO and coding without buying the actual switch can enable the rear fog light as DRL light?
What about F56 with just one foglight in the center? Would it be just one of the L or R in the coding?
edit:
I looked in BDC part of the coding, I don't think it can be mapped to DRL function. But maybe it'll work as Welcome Light. I'll have to try it out.
There's a typo in your code. Also, "Mapping_Nebelschlussl_L_Function" already had "nebelschlusslicht" as default value in mine.
Does adding the VO without adding the switch throws an error code?
Old Mar 24, 2015 | 06:17 PM
  #27
kevinminict's Avatar
kevinminict
So has anyone done this purchased the $100 switch, coded and succeeded? I have a 14' Cooper S and I have the rear fogs and bulbs! so weird.
Old Mar 25, 2015 | 07:15 AM
  #28
CooperB's Avatar
CooperB
Still on my bucket list but all you need is the switch and a quick code update and they will work. Discussed it at length here and with my dealer.
Old Mar 29, 2015 | 05:49 AM
  #29
darex's Avatar
darex
I'm just glad it's there (albeit non-functional). Looks better than the black hatched plastic insert they used to use on previous MINIs.
Old Aug 7, 2015 | 07:45 PM
  #30
nate09565's Avatar
nate09565
I just wanted to mention I followed the esys directions after purchasing the RFL headlight switch and was successful in coding the option into the vehicle.... Also coded in komfort access too, but the big win was RFL
Thanks again
Old Aug 8, 2015 | 06:41 AM
  #31
4151zero's Avatar
4151zero
Thanks again
So this was a drop solution, just buy the switch and code?
No addt'l parts?
Old Sep 12, 2015 | 10:07 PM
  #32
LordWinslow's Avatar
LordWinslow
Thanks again
I am bumping this again, so Add the switch, get the car coded and you have functioning Rear Fogs?
Old Sep 12, 2015 | 11:31 PM
  #33
Jas31483's Avatar
Jas31483
I, as well, am curious about this process. I just purchased the new control switch from my local mini dealer and it should be in by this coming weds. I have e-sys already up and running, however I'm a bit confused about this "add 5aa to the VO". I'm a newbie to this coding stuff, though I was able to go thru and program foldable side mirrors and fogs on with parking lamps, so I'm hoping someone in simple terms can explain it to me.
Thanks!
Old Nov 13, 2015 | 09:41 AM
  #34
MidnightF56's Avatar
MidnightF56
So now that we know it's relatively inexpensive to retrofit the rear fogs, is there any way to retrofit the front fogs?
Old Nov 13, 2015 | 09:54 AM
  #35
hp79's Avatar
hp79
Over $100 for a stupid switch is expensive, isn't it?
Front fogs are going to be way more expensive because you'll need to buy even more. Pretty sure it's doable though.
Old Nov 13, 2015 | 10:17 AM
  #36
MidnightF56
Well $100 is what it costs to order the car with the rear fogs anyway, so $112 isn't super unreasonable to do it after the fact.
Compare it to something like retrofitting the factory HIDs which basically triple in cost...
Old Nov 13, 2015 | 10:46 AM
  #37
MidnightF56
I'm looking at purchasing the new retrofit OEM DRL LED foglights from MINI.
So looking at:
-New Light Switch Module
-New Front Fog lights
-Updated coding
What else would I need for the retrofit?
Old Nov 13, 2015 | 11:03 AM
  #38
LordWinslow
So looking at:
-Updated coding
Possibly a new control module inside of the car for the lights as they are quite different than the normal lights. The heat sinks alone take up the whole rear of the lights and the lights are sealed up with only the main bus connector going into the light.
Old Nov 13, 2015 | 11:05 AM
  #39
MidnightF56
You're talking about the fog lamps? I've already got the LED headlamps.
I imagine that when you buy the DRL fog light retrofit kit, they provide any needed ballasts or whatnot.
Old Nov 13, 2015 | 11:18 AM
  #40
LordWinslow
Not so much ballasts but the control modules to make them work inside the car's control panel.
Old Nov 13, 2015 | 01:42 PM
  #41
vetsvette's Avatar
vetsvette
Moderator
Anyone have the part number for the switch? I already have the front LED fogs and just want to add the RFL.
Old Nov 13, 2015 | 01:53 PM
  #42
siriuszero's Avatar
siriuszero
Should be 61319301806 if you have auto headlights (which all US-spec 2015 F56s do), according to RealOEM.com
Old Nov 13, 2015 | 02:45 PM
  #43
vetsvette's Avatar
vetsvette
Moderator
Thanks for the part#. Found it for anywhere from $115 to $147. So, all I need is this and to have the coding done?
Old Dec 6, 2015 | 07:04 AM
  #44
bsajko's Avatar
bsajko
I've been searching previous posts for the steps to install the new light switch, but I didn't find any info...
Guessing the lower dash trim has to be removed? If yes, can anyone list the best way to do it?
Old Dec 6, 2015 | 07:47 PM
  #45
pjsjr13's Avatar
pjsjr13
Does anyone know if part #6131930 will work on a 2016?
Old Dec 7, 2015 | 10:49 AM
  #46
siriuszero's Avatar
siriuszero
For any 2016 MINI up until this month's production, yes. Looks like the part numbers changed for November production going forward, but I'm not sure what the difference is. No reason to think it wouldn't be compatible though.
Old Dec 7, 2015 | 04:28 PM
  #47
pjsjr13's Avatar
pjsjr13
Thank you
Old Dec 18, 2015 | 04:44 PM
  #48
pppdxx's Avatar
pppdxx
Just got my rear fogs done. 2016 July production F55 Justa.
Easy coding
Easy switch installation (99% by hand)
Total: 15 minutes
So magical to see a light bulb that had been there the whole time just light up after you press the switch!
Thanks to this forum and to ECS tuning.
Old Dec 21, 2015 | 06:32 AM
  #49
Easy coding
Total: 15 minutes
You are welcome.
Old Dec 31, 2015 | 01:41 PM
  #50
MarcoPolo's Avatar
MarcoPolo
had some free time today so i did it as well. took awhile cuz i was having some soft token pin issues with e-sys, otherwise it was a 1-2-3 job.
