F55/F56 First Fault
First Fault
Pulling into my parking space after commuting home this afternoon and this little jem popped up on the screen. I shut down the car and restarted it and the problem was gone. Called the dealership and they said it could have just been a glitch and to not worry about it unless it pops up again.
^Hope it's not the ABS control module, after you get that message, does the car still intervene in hard cornering and braking the rear inner wheel? If the stability control/traction control gets turned off in the middle of driving it could cause you to lose control at the limits (it could over-steer if you turn sharp and lift off for example, it happened to me on another car). Have the dealer read the codes off the computer - it should store them even after the message is gone-and it goes away probably after you turned the car off and on again, right?
Yeah, the fault went away as soon as I turned the car off and back on again. I haven't driven it since I got home to notice any changes in the driving dynamics, but will keep an eye on it this evening.
Did you see Dr. Mini's post "New MINI Drivetrain Malfunction"? Apparently, he also had the chassis stabilization/drive moderately message come up. His is at the dealership and the service department is consulting with the engineers.
Pker
Apr 11, 2017 12:14 AM
jetmechinnc
Nov 18, 2015 08:54 PM
reg66
Aug 31, 2015 02:41 PM
