F55/F56 F56 Lug Pattern
Old Apr 9, 2014 | 06:40 AM
  #26
minsanity's Avatar
minsanity
Where did MINI borrow those F56 hubs from????? 4x100 or 5x120 would've been just fine!!!! What were these guys on this time???? Sorry for the rant!
Old Apr 9, 2014 | 07:56 AM
  #27
VicSkimmr's Avatar
VicSkimmr
Originally Posted by R99
Where did you find the pictures??
I have rang my local dealer - but they were useless!!
I have sent an e-mail to MINI also, but I'm not holding out too much hope for a reply!
mosey on over to m|u
Old Apr 9, 2014 | 04:42 PM
  #28
gtmotor's Avatar
gtmotor
Wow that is crazy... if I had time I'd go down to the dealer and just measure it real quick with a set of calipers.
Old Apr 9, 2014 | 05:30 PM
  #29
hammerhands's Avatar
hammerhands
Would the lug information be on the door frame? In the Owner's Handbook?
Old Apr 9, 2014 | 05:35 PM
  #30
minsanity's Avatar
minsanity
Can anyone confirm 5x112/66.5 bore?
Old Apr 10, 2014 | 07:23 AM
  #31
cristo's Avatar
cristo
Alliance Member
The info should be cast into the back of the wheel.
It is for most wheels.
Gotta take the wheel off, though to see.
Amazing that this isn't published yet.
Old Apr 10, 2014 | 09:56 AM
  #32
hammerhands
What if someone stole your wheels? It must be somewhere!
Old Apr 10, 2014 | 10:33 AM
  #33
VicSkimmr's Avatar
VicSkimmr
Unfortunately it isn't.
Old Apr 10, 2014 | 05:08 PM
  #34
junkart's Avatar
junkart
confirmed. Did you get this info from Scott @ Magic?
Old Apr 11, 2014 | 08:44 AM
  #35
randomquickness's Avatar
randomquickness
is this really accurate? I don't want to believe a BMW developed car is switching to a VAG/MB bolt pattern. Especially since Apex Race Parts has a set of 17x8.5 wheels that weigh 17.2 lbs each in 5x120 et 40 or 42.
Old Apr 11, 2014 | 09:18 AM
  #36
HorseWithNoName's Avatar
HorseWithNoName
So 5x112/66.5 bore is the wheel size on the new F56?
Old Apr 11, 2014 | 09:30 AM
  #37
GEMSTER's Avatar
GEMSTER
100% sure it is 5x112 and 66.5.
Old Apr 11, 2014 | 10:20 AM
  #38
rkw's Avatar
rkw
It is GOOD news!
5x112 is a popular bolt pattern with a large selection of aftermarket wheels.
Old Apr 11, 2014 | 01:16 PM
  #39
daffodildeb's Avatar
daffodildeb
Along the same lines, will the Enkei wheels I have on my R56 work? They are 16" and I plan to get 16s on the new car. I think they are RPF1 but I bought them from a friend off HIS R56, so I'm not sure. Sorry, I don't know all the dimensions and technical stuff, but are they likely to work?
Old Apr 11, 2014 | 01:25 PM
  #40
SoCalledFriend's Avatar
SoCalledFriend
No.
R56 = 4 lug
F56 = 5 lug
Old Apr 11, 2014 | 01:29 PM
  #41
rkw's Avatar
rkw
Not at all. 4 bolts vs 5 bolts.
Old Apr 11, 2014 | 01:51 PM
  #42
VicSkimmr's Avatar
VicSkimmr
But on the plus side, we have a lot more options for RPF1s in the new bolt pattern if you're not afraid of wobble bolts.
Old Apr 11, 2014 | 03:12 PM
  #43
daffodildeb
Bummer. Guess I'll have to sell them separately (still have the stock wheels).
Old Apr 11, 2014 | 05:36 PM
  #44
minsanity's Avatar
minsanity
Yup, Motoring Magic got NM Engineering to confirm from their F56. It's exactly 5x112/66.5 bore.
Now, those who are awaiting delivery can shop wheels ahead. Stock has et54. Not sure how low the offset could go. NM will surely come out w/ F56 line of wheels. They'd know the offset range w/ the camber in spec.
Old Apr 13, 2014 | 01:49 PM
  #45
marcussoori's Avatar
marcussoori
Since tirerack.com and other sites don't yet have the F56 Mini wheel and tire sizes loaded yet, should we use the 2008 Audi A4 FWD stats when searching for new wheels?
http://www.wheel-fitment.com/PCD/5x112/66.5/
Old Apr 13, 2014 | 02:58 PM
  #46
VicSkimmr's Avatar
VicSkimmr
That will probably work. Tire rack is pretty conservative about their fitment ideas so even though the Audi probably has larger stock wheels anything that they say will fit it will probably fit an F56.
We don't know anything about offsets for the F56 though, and the suspension is completely different, so there is a caveat. We won't actually know until people start bolting wheels up.
Old Apr 13, 2014 | 03:02 PM
  #47
danjreed's Avatar
danjreed
Originally Posted by VicSkimmr
That will probably work. Tire rack is pretty conservative about their fitment ideas so even though the Audi probably has larger stock wheels anything that they say will fit it will probably fit an F56. We don't know anything about offsets for the F56 though, and the suspension is completely different, so there is a caveat. We won't actually know until people start bolting wheels up.
Heads up, Audi wheels are ball seat bolts, BMW/Mini are cone shaped.
Old Apr 13, 2014 | 04:14 PM
  #48
MINIAC's Avatar
MINIAC
We don't know anything about offsets for the F56 ...
They're listed on RealOEM:
ET46 for 15" wheels
ET54 for 16", 17" and 18" wheels
Old Apr 13, 2014 | 04:55 PM
  #49
junkart's Avatar
junkart
YES! Good point!
AND not all Audi wheels, just the late model '08~up will work as the older cars came with 57.1mm hub bore.
Old Apr 13, 2014 | 06:53 PM
  #50
minsanity's Avatar
minsanity
Just use the Audi ball seat bolts. Make sure they're M14x1.25.
The gen1s pull off 15s very well. I think they'd look odd on the F56.
