F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Brake booster noise?
Old Nov 28, 2021 | 05:13 AM
skoukiadakis's Avatar
skoukiadakis
New here and starting questions…
Any idea of the best way replacing brake booster in F56 JCW ?
The booster works perfectly , although there is a squeezing noise when pressing the pedal !
Is there any other fix except replacing brake booster ?
Thank you in advance!
Old Nov 28, 2021 | 10:25 AM
RichsMINI's Avatar
RichsMINI
Hi skoukiadakis,
I don’t know of an easy way to replace the brake booster but I have seen an older thread about a similar issue on this forum.
Here’s the link, the user did mention bleeding the brake lines.
https://www.northamericanmotoring.co...ake-pedal.html
Here’s another link to a different MINI forum and supposedly four other MINIs made the same sound.
https://www.minif56.com/threads/hiss...service.77858/
When I apply pressure to the brake pedal and the MINI is not running I can hear a sound from pressure building and can feel it in the pedal.
While driving and applying pressure to the brake pedal I don’t hear anything from inside the cabin and outside I can slightly hear the brake pads pressing against the rotors.
I hope the issue gets resolved,
Rich
Old Dec 14, 2021 | 08:40 PM
skoukiadakis
Originally Posted by RichsMINI
Hi skoukiadakis,
Rich
Thank you for your response.
The problem solved.
Strange but the problem was not the brake booster.
It was the brake pump , the noise came inside the pump.
verveAbsolut
Apr 9, 2015 07:38 PM
dianna912
Oct 16, 2008 01:26 PM
lns1122
Tires, Wheels, & Brakes
Feb 22, 2007 07:33 AM
dominos
Jan 31, 2007 12:27 PM
