HELP - Release PEDAL BRAKE NOISE
Hi NAM Readers,
After braking, when I release my pedal brake, it makes a swoosh noise? like an injection noise?
Do you have the similar problem before? what's that?
Thanks,
dominos
Thanks,
dominos
A hissing or swooshing sound when applying or releasing the brakes indicates a leaky power brake booster. Shut the engine off and listen. if a hissing sound occurs for a few moments afterwards, it's leaking. Test for leaks by shutting off the engine and waiting about a minute. Press the brake pedal. if it feels hard to press, the booster has a leak. If it hisses while pressing the brake pedal, the valving is bad and the booster needs replacing.
LordOfTheFlies
Oct 19, 2015 05:02 PM
