F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Steering Wheel replacement due to faulty horn?
Old Dec 30, 2020 | 07:42 AM
Luvtwisties's Avatar
Luvtwisties
Anyone have a problem with a faulty horn due to worn contacts located within the steering wheel?
My '16 F55 is at the local Charlotte dealer for normal maintenance and they've determined the culprit are worn brass horn contacts located behind the airbag. Due to the complexity of the innards of the steering wheel, there are no parts replacement, no adequate cleaning, no sanding, no repair etc. The ONLY fix is a new $950 steering wheel! BMW assistance will cover $600 but still quite a shock for a horn fix. Dealer service has always been first rate so no problem with them; frustrated with the factory solution.
Apparently a fairly common BMW problem from what I've read in various blogs.
Any suggestions?
Old Jan 3, 2021 | 11:14 AM
curlywurly's Avatar
curlywurly
My dealer replaced my wheel* under warranty for the faulty contacts/horn issue this autumn. Car was in for an oil change and they went thro all the service updates. Id not noticed Maybe worth mentioning to the service rep you are aware of a known issue - and appeal to their better nature on any out of pocket you are on the hook for.
Other way to address this would be: if you quite like the mini yours or JCW wheel - get them to replace your wheel with one of those - telling yourself a couple of hundred for an upgraded wheel isnt the worst thing to happen.
Old Jan 4, 2021 | 08:58 AM
Luvtwisties
Thanks;
Local dealer contacted BMW assistance who paid 75% for parts/labor. Odd problem but it was out of warranty
Old Jan 4, 2021 | 11:21 AM
ajseymour's Avatar
ajseymour
Horn replacement.
Must be common enough as I remember when I had my F55 my dealer replaced mine under warranty and made a comment that it wasn’t the first he had done. That was about three years ago.
mike chua
Feb 12, 2017 07:39 PM
bsures
May 29, 2012 03:34 PM
mk1mini
Feb 6, 2008 07:44 AM
mjfarsi
Jan 12, 2004 06:50 AM
BobLane
May 23, 2003 08:56 AM
