F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
TPMS Issue - Sensor/Module Location
Old Jan 26, 2020 | 05:33 PM
rikhemi's Avatar
rikhemi
Having an issue with my TPMS registering the tire pressure on my Mini Cooper Type S. Seems like the module is defective since its not getting any reading from any tires. Everything was working fin e the past year and last week, It advised me that there was an issue with the reading and to reset the tpms. I tired resetting the tpms a few times and nothing changed. I tried searching for the module/antenna but the only one I found, from reading some other post, was the one in the rear bumper, which seems to be an antenna for comfort. Has anyone had this issue? Can someone direct me to where the control module is for the TPMS and the antenna? I highly doubt all 4 tires at the same time became defective so I'm assuming switching out the module or antenna will correct the issue. Thanks in advance.
Old Jan 26, 2020 | 06:00 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.newtis.info/tisv2/a/en/f...rol/1VnXTRI15v
Old Jan 26, 2020 | 07:14 PM
rikhemi's Avatar
rikhemi
Thanks for the link. So is the tire pressure indicator feature integrated to the dynamic stability control? So to replace the tire pressure indicator, this piece would need to be replaced? Do I need to remove the bumper to get to this piece or can I remove the trunk panels on the right side to get to it?
It specifies the remote control receiver is connected to the Body domain controller, via the can bus. Where would that be? Is there a way to determine/test if the remote control receiver is the issue vs the tire pressure indicator? Thanks again for your help. Car has 14k miles and didn't think these issues would pop up this soon.
Old Jan 26, 2020 | 07:37 PM
Minnie.the.Moocher
The newtis site should have answers for you. I am not familiar enough with it to help diagnose. Are you out of warranty?
Old Jan 26, 2020 | 07:39 PM
rikhemi's Avatar
rikhemi
Unfortunately I am. It’s 2015.
Old Jan 26, 2020 | 07:41 PM
Minnie.the.Moocher
The only other thing I'd check is if your main car battery is in good condition. Sometimes a failing battery will cause failure on other components as an early warning sign.
Old Jan 29, 2020 | 05:01 AM
rikhemi's Avatar
rikhemi
Any other ideas of what it can be or if maybe there was a TSB on this issue?
Old Jan 29, 2020 | 06:57 AM
robby71's Avatar
robby71
Does this help? - https://www.newtis.info/tisv2/a/en/f...rol/1VnXTRI15v
It shows there is also a remote control receiver
Old Jan 29, 2020 | 07:03 AM
rikhemi's Avatar
rikhemi
Thanks for the reply. Minnie actually sent me this originally. The document doesn’t specify where the remote receiver is, just talks about it. I believe to have found the module, just can’t seem to locate the antenna.
Old Jan 29, 2020 | 07:24 AM
robby71's Avatar
robby71
I would expect it to be close to the BDC in 1 of the footwell kick panels
Old Mar 28, 2020 | 08:24 AM
shpuncik's Avatar
shpuncik
The reciever from newtis link is located on the right side just down the C-pillar behind trim (at least on F55). Fuse #42 on BDC powers it up but if there is no power to aerial then whole central locking/TPMS/car starting won't work - need to put key next to steering column to start it.
It's just simple aerial for TPSM and key fob to operate central lock. If central lock works fine I'd run diagnostics on car.
Worth checking this topic: https://www.northamericanmotoring.co...k-anymore.html
10Zero
Tires, Wheels, & Brakes
Jun 14, 2022 01:23 PM
Revdoc
Electrical
May 4, 2020 08:40 PM
lesg45
R55 :: Clubman Talk (2008+)
Feb 2, 2020 04:39 AM
CMongoose
R60/R61 Stock Problems/Issues
May 2, 2018 01:55 PM
Dr. Bimmer11
Oct 3, 2015 04:52 PM
