torque settings
So the Bentley has 3 torques listed. Looks like there are 3 different lengths of head bolts? it also says to replace the bolts.
m8x35mm is 22.1 ft-lbs
m8x95mm is 11 ft-lbs then additional 90 deg then another additional 90 deg
m8x145mm is 22.1 ft-lbs then additional 90 deg then another additional 90 deg
The camshaft sprocket bolts are different for the intake (VANOS) and exhaust. it also says to replace the bolts.
Intake (VANOS) is 15 ft-lbs then additional 180 deg
Exhaust is 14.7 ft-lbs plus additional 90 deg
LordOfTheFlies
Oct 19, 2015 05:02 PM
minipopkart
Aug 13, 2015 05:22 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
