F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
High Pitched Whine
Old Nov 1, 2014 | 03:28 PM
hammerhands's Avatar
hammerhands
High Pitched Whine
When the ignition is on, the engine is off and I'm outside of the car I can hear a very loud high-pitched whine, like the sound a cathode ray tube makes, or the ringing of light bulbs that shouldn't be on a dimmer switch, but louder.
It sounds like it comes from under the hood, but it's really hard to pinpoint.
You can't hear it inside the car.
I assume this is normal! It should keep the mice out.
Old Nov 1, 2014 | 03:39 PM
hp79's Avatar
hp79
Could be the fuel pump, which is normal. My Mazda makes this noise too when I'm in the garage.
Be aware, with ignition on, battery drains pretty quickly. I experienced this on a cross country in a 2000 Saab 9-5 couple years back. I was about to turn the engine on, but right before that wife and I was talking about where to go first. In about 10 minutes, the battery died and needed a jump start.
Old Nov 2, 2014 | 06:02 PM
2004MCS's Avatar
2004MCS
Do you have LED headlights? I've noticed the same sound and found it's coming from fans inside the LED headlights. With the bonnet open and using a flashlight you can see the fans through the clear plastic that is on the top back section of the lights.
Just opening the drivers door makes the fans spin up for some reason. If I don't start the car, the fans will stop after about a minute.
Old Nov 2, 2014 | 06:06 PM
DneprDave's Avatar
DneprDave
My wife makes a high pitched whine, when I take the corners fast!
Old Nov 2, 2014 | 08:48 PM
hammerhands
No LED headlights, and it doesn't stop.
Old Nov 2, 2014 | 10:06 PM
bjcarter2's Avatar
bjcarter2
Power steering fan or pump maybe?
Old Nov 5, 2014 | 10:01 AM
hammerhands
Here's a video, if you can stand me breathing like an obscene phone caller.
I thought it could help me find the source, it didn't.
When I opened the hood I could hear a slight whirr along with it, you can hear it in the video if you have headphones on, so I guess it could be mechanical.
Strangely, when I was at the engine it sounded like the noise was coming closer to the firewall, and maybe deep in the engine, but on the video it gets louder near the front.
I'm getting winter tires this week or next, I will ask then.
lweaver
Sep 17, 2024 08:22 AM
Casrio
Apr 20, 2021 01:52 AM
Camaro108
Sep 9, 2015 04:37 PM
Camaro108
Sep 9, 2015 01:56 PM
