F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Rear Split Door Handle Replacement?
Old Jan 12, 2024 | 02:49 PM
DeanFlowers's Avatar
DeanFlowers
I've looked and looked and looked for weeks now on how to remove the orginal handles to replace them with custom plated ones I have, but so far no luck. Can someone help me out?
Old Jan 16, 2024 | 07:08 AM
Hello,
Here are the blackline Genuine MINI ones for example.
https://www.northamericanmotoring.co...r-handles.html
You can see two screws and you will have to take the door inside panel to replace.
https://www.ecstuning.com/b-genuine-...w/07129904831/
Those are torw screws, you will need a torx set . https://www.ecstuning.com/b-schwaben...et/hbs-m9pcst/
Then you will have to Ignore the red arrow, but look above it and you will see a circular rubber plug on the inside jam to access one of the screws and the other is behind that window wiper motor. Then just plug the new one in and bolt up.
Get a trim tool kit so you dont beat up the inside panel.
https://www.ecstuning.com/b-schwaben...ieces/phr-11s/
Inside Barn door Panel diagram : https://www.realoem.com/bmw/enUS/sho...diagId=51_3811
Number one and number two panels can come off, might be too hard with just the number sixes removed.
What it looks like on the body metal side outside stamped metal barn doors.. https://www.realoem.com/bmw/enUS/sho...diagId=41_2565
smith80678
R58 :: Coupé Talk (2012+)
Jun 14, 2017 02:25 PM
Coxster7
Jun 28, 2015 09:08 AM
andys2mini
May 25, 2012 11:37 AM
MDriver
R55 :: Clubman Talk (2008+)
Apr 18, 2008 09:34 PM
