F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 All4 oil pan removal difficulty?
Old Nov 28, 2023 | 08:37 AM
reidmefirst's Avatar
reidmefirst
I was perusing reddit and came across a post that mentioned an aftermarket oil pan option, with a handy-dandy oil dipstick tube. Specifically, this: https://garage34racing.com/products/...ick-conversion
I wonder if anybody has removed their oil pan, on an All4 F-series MINI? Is it a PITA to do (i.e. does it require dropping the transfer box like in the previous gen paceman/countryman)? I found some forum posts noting that on R series MINIs it could be done just by loosening the transfer box and lowering it slightly, but reinstallation sounded terrible (one thread noted they had to shorten one of the oil pan bolts because they couldn't manage to feed it back up in tight space, so really removal of the transfer box is required....).
I'm kinda thinking about doing it, as well as comparing the stock oil pan to this one. It looks like the stock pans are almost-but-not-quite set up to have a dipstick tube mounted on the side. Call me old-fashioned but I always like having a tube so that I can check my oil while the car is off...
Old Nov 28, 2023 | 11:01 AM
We have aftermarket ones here in stock, i bet he is just buying ours (drilled it) and putting a dip stick in it from what looks like an R50/R52 dipstick. looks like the one on my r52?
We have the pans here and they have the casting like the genuine one and its blocked off: https://www.ecstuning.com/Search/Sit...h/11138590017/
Yes have not seen ones change, most people are doing the filter housing, but yes you would have to take those bolts out and tilt the transmission out a little.
https://www.northamericanmotoring.co...lock-help.html
Old Nov 29, 2023 | 07:54 PM
paulsminis's Avatar
paulsminis
I hit a rock in northern Michigan and cracked the sump on my 2020 F54 All4. I didn’t replace the sump but carefully followed the dealer’s service staff as they did it. They had to drop the exhaust to get at it. They did it in an afternoon, but the special sealant has to cure for 12 hours. Replacement pan was factory and it came with the required sealant. Wish I had known there was an aftermarket pan as it would have saved me some $$.
Old Nov 30, 2023 | 08:04 AM
Yep, we have more and more aftermarket landing ever day under Bremmen Parts. https://www.ecstuning.com/b-bremmen-parts/v-mini/
We have install kits also that come with the sealant, elring is oem on most gaskets and sealant without the MINI high prices Under assembled by ECS.
https://www.ecstuning.com/b-assemble...11138590017kt/
To protect the pan for the F60/F54
https://www.ecstuning.com/b-m7-speed...70-130100~m7s/
Old Nov 30, 2023 | 12:16 PM
paulsminis's Avatar
paulsminis
ECS Tuning : I checked your link For the protection plank and in the “fits these cars” it says it doesn’t fit F54 JCW all4.
Old Dec 1, 2023 | 01:18 PM
Glitched, i fixed it.
Aidian Holder
Aug 22, 2022 11:11 AM
user 80823208
Jun 28, 2021 06:49 AM
frankiev
Mar 10, 2020 05:07 PM
Cngizbleevng
Dec 21, 2014 03:10 PM
ScottRiqui
16
Dec 4, 2006 01:34 PM
