F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 F54 Upper Engine Mount busing replacement
Old Feb 25, 2023 | 04:28 PM
AJCM's Avatar
AJCM
Hello everyone,
I would like to know the tips to replace upper engine mount. Besides the headlight, do i have to remove anything else in order to access and remove the upper engine mount?
Thank you for any helps and tips
Old Mar 1, 2023 | 06:42 AM
https://www.northamericanmotoring.co...acement-4.html
Old Mar 1, 2023 | 10:24 AM
Michael Hayes's Avatar
Michael Hayes
I had mine replaced at the dealership yesterday. I had 52,000 miles on it. It was very costly.
Old Mar 2, 2023 | 10:14 AM
EmedpaDHSc's Avatar
EmedpaDHSc
mine was done at 65k at an independent shop. I had them put in the powerflex bushings to hopefully extend the life a bit. It was spendy indeed, but about 1/3 less than the dealer wanted for the same part.
Old Mar 3, 2023 | 09:13 PM
AutoCoarsen's Avatar
AutoCoarsen
I have some posts in that linked thread above. On my ‘17 S ALL4 Manual transmission I only need to remove the headlight. I’ve done it a bunch testing different mounts and it can be done in about 1 hour with practice.
There’s a lot of wiggling and trying different angles to squeeze it in and out, but it’s absolutely possible (without removing & opening A/C pipes).
It also helps to keep the jack under the engine (place it where the lower torque mount attaches) and move the engine up/down a few inches while trying to get the mount in/out. It’ll help get the mount in/out - allows different angles.
There also a little screw behind a plastic shield.
I’d have to track down a photo to point it out. I actually cut a small hole in the plastic shield to access the screw. I hate to hack stuff like that, but it will save a huge amount of time and is a cheap, hidden piece.
Old Mar 3, 2023 | 09:18 PM
AutoCoarsen
I’d also order 2x part number 64539209732 “ball pin” and 2x 07149209733 “pipe clip”. They screw into the mount and clip around AC lines. Very easy to break.
https://www.realoem.com/bmw/enUS/sho...diagId=64_2045
ninjatuna
14
Sep 24, 2021 09:20 PM
Systemlord
Mar 13, 2016 10:34 AM
jd_Smith06
Mar 1, 2014 11:31 AM
khor1287
Oct 31, 2013 03:54 PM
