F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Correct Rear Differential Fluid? ALL4
Old Dec 19, 2019 | 02:53 PM
AutoCoarsen's Avatar
AutoCoarsen
Does anyone know the correct rear differential fluid for the F54 S ALL4?
RealOEM shows
“Hypoid axle oil G3” 83222413512
It also mentions the rear diff is “
Rear-wheel drive without hang on clutch” Whatever the “hang-on clutch” is??
The TIS shows the F54 uses BMW HOK Oil, or Hang on clutch oil. 83 22 2 413 513
https://www.newtis.info/tisv2/a/en/f...ive/1VnczONFlo
HOK oil appears to be some sort of Haldex system fluid.
Old Dec 21, 2019 | 09:53 AM
AutoCoarsen
I got under the car and it appears there’s two reservoirs for fluid. A standard differential fill plug, then on the left side of the AWD unit, another small fill plug. That must be what uses the HOC fluid.
#9 is the “tank” cover which uses sealant to seal to the AWD unit. #12 is the fill plug.
https://www.realoem.com/bmw/enUS/sho...65#33118600494
And I totally missed the TIS procedure in it.
https://www.newtis.info/tisv2/a/en/f...ive/1VnYzScwuq
Old Dec 27, 2019 | 10:17 AM
WhatV8's Avatar
WhatV8
Looks like you found your answer already. Our cars use an electronically controlled 'wet' clutch center diff for front/rear torque distribution that is co-located in the rear differential housing, but obviously segregated from a fluid standpoint. I thought that was interesting when I discovered the setup, compared to my former Subaru.
entropy1
16
Jun 11, 2024 08:47 AM
MTBatmanMINI
R60/R61 Stock Problems/Issues
Oct 25, 2018 03:14 PM
pkunk
Jul 6, 2017 03:13 PM
BRGDragon
Feb 6, 2013 06:00 PM
flav
Apr 28, 2008 12:28 PM
