F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Bimmercode app
Old 11-29-2017, 02:47 PM
godskid's Avatar
godskid
godskid is offline
Weird. My F54 clubman has always opened on one pull of the door handles, even when locked. (with engine off). At least, the driver's door does. I've not had occasion to try the passenger side.
I thought they had done away with the 2-pull bit. (It always made my mother pull too hard on the handle, and try to break it off.)
edit: I'm not the first owner, though.
  #102
Old 11-29-2017, 03:16 PM
pjo1966's Avatar
pjo1966
pjo1966 is offline
Originally Posted by vetsvette
I didn't link it with my car, but the option shows up in demo mode on my app.
It shows up in mine on demo mode as well. I wish I had more time to play around with this.
  #103
Old 11-30-2017, 01:29 PM
MarcoPolo's Avatar
MarcoPolo
MarcoPolo is offline
you may be misunderstanding. the car does unlock with 1 pull, not two. this is a better example. i shut off the car, i pull the handle, door opens, i get out, go around to grab something from the passenger side, door locked. if i left the keys in the car, now i have to go back around and either press the unlock button on the door to unlock just the passenger side OR use the remote to unlock the passenger side. this has been an ongoing issue with me. the only solution is to press the unlock button on the door so that when you go to the other side, the door is unlocked.
onto the coding, unlock with engine off was removed from all F Series BMW's until someone figures it out. it's not just mini's, doesn't work on any BMW. i attempted it on an M3 and M4. neither worked. google search shows this is an across the board issue.
  #104
Old 11-30-2017, 01:34 PM
godskid's Avatar
godskid
godskid is offline
Ah, I see. Sorry for interrupting. (I would never want all my doors to unlock when the engine stops. Urban dweller here.)
  #105
Old 11-30-2017, 01:37 PM
siriuszero's Avatar
siriuszero
siriuszero is offline
They did change the parameter on newer software versions so the coding is different. I had to find the right thing to change when I had a software update done on my F55 and again when I bought my Connected 5.0 equipped Clubman. Haven't seen a 2018 model though...
It will be one of these in the BDC - change to "aktiv":
VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK
CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING
CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK
  #106
Old 11-30-2017, 01:55 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
When someone verifies which code works please let me know and I'll add it to FAQ.
  #107
Old 11-30-2017, 02:42 PM
pjo1966's Avatar
pjo1966
pjo1966 is offline
I could have written this post. It's so irritating.
  #108
Old 12-01-2017, 10:04 AM
pjo1966's Avatar
pjo1966
pjo1966 is offline
I'm not seeing any of these. This is everything under 3040. There's one that has KL15, but it's already listed as aktiv.
Attached Thumbnails Bimmercode app-code-1.png   Bimmercode app-code-2.png   Bimmercode app-code-3.png   Bimmercode app-code-4.png   Bimmercode app-code-5.png
  #109
Old 12-01-2017, 04:10 PM
pjo1966's Avatar
pjo1966
pjo1966 is offline
My Mini has the basic Bluetooth - calls only. Is there a code to activate full music streaming from my phone, or is that a hardware issue?
  #110
Old 12-01-2017, 07:51 PM
MarcoPolo's Avatar
MarcoPolo
being worked on...but currently no solution. same situation here. i'm using a Tune2Air for the time being but am considering aftermarket HU...yes i'm aware i lose access to the settings....don't care.
  #111
Old 12-01-2017, 08:38 PM
pjo1966's Avatar
pjo1966
pjo1966 is offline
I've been using a cheap BT adaptor to stream audio. I only have three months left to my lease and the next Mini will have the tech package. I was just curious.
  #112
Old 12-03-2017, 09:26 PM
pjo1966's Avatar
pjo1966
pjo1966 is offline
I see that the app was updated. Any idea what is new?
  #113
Old 12-04-2017, 06:38 AM
MQQN's Avatar
MQQN
MQQN is offline
I ordered and received the Vgate iCar Pro Wi-Fi OBD2 dongle and it would not communicate with my 2017 MCS either it is defective or the wrong item so I'm returning it and I ordered the Vgate WiFi2 OBD2 Elm327 dongle to replace it. I am hoping this works.
  #114
Old 12-04-2017, 07:15 AM
vetsvette's Avatar
vetsvette
Moderator
This is what I ordered and it works.
Amazon Amazon
MQQN (12-04-2017)
  #115
Old 12-04-2017, 07:40 AM
MQQN's Avatar
MQQN
MQQN is offline
thanks that is the one I just ordered
  #116
Old 12-04-2017, 08:09 AM
punkgeek's Avatar
punkgeek
punkgeek is offline
btw - on my android phone I had the same behavior _until_ I turned airplane mode on and then wifi on (to effectively turn off mobile data). I think bimmercode doesn't cope properly when there are multiple network interfaces.
  #117
Old 12-04-2017, 08:13 AM
vetsvette's Avatar
vetsvette
Moderator
I use my iPad for programming. I disable BT and all other wifi connections before starting to program. No Problem so far.
  #118
Old 12-04-2017, 08:42 AM
pjo1966's Avatar
pjo1966
pjo1966 is offline
Mine works fine after first saying it can't connect. I try a second time and it's fine.
  #119
Old 12-04-2017, 09:32 AM
I'mMelting's Avatar
I'mMelting
I'mMelting is offline
That is how mine works as well. I think I will try disabling BT and other WIFI as Vetsvette suggests and see if that avoids the second start. NBD either way I guess.
  #120
Old 12-04-2017, 11:00 AM
pjo1966's Avatar
pjo1966
pjo1966 is offline
Disabling BT and mobile data seems to be more work that just hitting the Connect button again.
  #121
Old 12-06-2017, 03:42 PM
pjo1966's Avatar
pjo1966
pjo1966 is offline
Just checked again now that the app has been updated. The option to unlock when I put the car in Park is still not there.
  #122
Old 12-20-2017, 08:37 PM
autoxtech's Avatar
autoxtech
autoxtech is offline
ok thanks for all the help , i did manage to get the rear fog lights to work as brake lights in expert mode, but i did loose the lights in the bumper only the outside works ( i have not done the factory update for brake lights yet )does any body know if they can all work still , thanks for the help
courtney
  #123
Old 12-25-2017, 09:21 PM
GDGR's Avatar
GDGR
GDGR is offline
I finally got a programmer (wifi ob2 dongle and the Bimmercode app), as a nice gift from the family. So, I've made three changes to my '16 Clubman S:
1 - The radio will now turn off when I open the door. This has really pissed me off since day 1.
2 - I got rid of the nag screen. I've had lots of cars that do this so I'm sort of used to it, but I'm glad to see it go.
3 - I programmed it to show tire temps as well as pressures.
I haven't actually DRIVEN it yet so I'm not sure if these all "took" or not, but I hope so! I'm a little surprised that the thing measures tire temps at all.
Also coming soon - a lighted shift ****. I'm surprised that I've missed this, but as I've had three BMWs with the feature I really do notice the lack of it.
I'm going ahead and donating another 200 internet points to charity in @2017All4's name since I'm still not using the automatic mirror folding option.
  #124
Old 12-26-2017, 07:57 AM
2017All4's Avatar
2017All4
2017All4 is offline
Super Moderator
Remember, a folding delay can be coded so one has the option for autofold/unfold by holding down the lock or unlock button on the fob a bit longer. And one doesn't have to use the feature. Sorta like concealed carry. Don't have to use it but it's there if you need it. And it is most entertaining, especially for anyone watching you do it, to learn just how long to hold the button on the door or the fob... cheap thrills.
If mine weren't a leased car, I might be concerned that the fold motors might fail after a few years from constant use.
On behalf of the Home for Wayward MINIs, your generous donation of internet points is gratefully acknowledged. Happy Holidays.
  #125
Old 12-28-2017, 02:14 PM
darex's Avatar
darex
darex is offline
Which shift ****? ICT's?
I installed theirs in both my F56 and F60. Can't stand the stock one, both how it looks and feels.
Took me a while to work out where to access 12V in the F60, but did so a few weeks ago.
Looks 100x better than stock, and SHOULD be MINI's choice for stock IMHO.
