Electrical My power outlet is broken
Old Apr 30, 2007 | 07:38 PM
in the flesh's Avatar
in the flesh
Like the title says my outlet is broken so i have to use the one in the boot to power my ipod. Is there a cord extender so the ipod can reach my cupholder under the toggles. Cause I have to reach back to the backseat to select a song and its becoming very annoying
Old Apr 30, 2007 | 07:58 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Radio Shack sells an extension cord you can use. Lighter plug on one end, socket on the other.
Old May 1, 2007 | 06:32 AM
hunter99's Avatar
hunter99
Mine did hte same thing a couple of weeks ago. I had to go by the dealer (hour and a half away) to get the alarm programmed so I had them look at it.
Basically ended up being the 2 prongs inside it got bent a little too far outwards and were not making good contact. The service guy just bent them back and they work fine now. Strangly, the lighted ring around the plug is not working.
I would try that first. What did it on mine was the cig plug for the Garmin 660 I have. It has very strong prongs and caused them to get bent.
Old May 1, 2007 | 06:36 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Same thing here with the prongs. Pull it out and push everything together, and see if that helps at all.
Old May 1, 2007 | 07:00 AM
Loony2N's Avatar
Loony2N
But don't stick your tongue in there. Very salty.
Old May 1, 2007 | 09:42 AM
supercliff's Avatar
supercliff
If your plug is bad (and fuses are ok), you can also replace the lighter socket. The P/N is 61-34-6-973-035 and costs $3.24 from Classic Mini. If your light also needs replacing the bulb P/N: is 07-50-9-063-579 and costs $2.08. (the bulb+the bulb socket is 61-34-6-915-065 and costs $3.02).
I know because I just ordered this stuff to add the cig in the boot (I have an 03 which didn't have one there).
Filmy
Apr 28, 2019 11:37 AM
67morris
Dec 1, 2015 12:53 PM
R60SX
Sep 23, 2015 09:01 AM
ou812_tugger
Sep 5, 2015 03:24 PM
Ntety
Sep 2, 2015 08:39 PM
