Electrical "Extreme Problems"...
Old Mar 15, 2007 | 03:04 PM
cartar452's Avatar
cartar452
So today I took my MCS into a local garage to check the A/C because it hasn't been blowing cold recently. *I have in the past month installed a Megan Racing Header, new ignition parts (plugs, wires, coil), and springs.* Ever since I had all that installed, my check engine light and ASC light have been on. Here's what the shop had to say...
"We found that the system is full but the compressor is not coming on. We checked the fuses and found that the fuse to the relay control module is blown. We replaced the fuse and checked the circuit. The draw is only 2 amps. We ran a computer scan and found codes PO031, PO037, PO340 and PO445. The codes do not have anything to do with the A/C. We could see that the systems that are effected are starting to cause other problems. More testing will be needed to be able to fix the problems. The A/C may or may not keep working."
Anyone have any ideas about what's going on with my car?? What do those codes mean? Should I take it to the dealer? Please help :impatient
Old Mar 15, 2007 | 03:35 PM
chows4us's Avatar
chows4us
P0031 HO2S Heater Control Circuit Low
P0037 HO2S Heater Control Circuit Low
P0340 Camshaft Position Sensor "A" Circuit
P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
Take it to the dealer but dont be surprised if they say your mods caused it and its on your nichel to fix it
Old Sep 8, 2007 | 08:14 PM
62minimn's Avatar
62minimn
Same Combination of codes
Have your resolved this issue of codes? I have been getting the same group.
Old Dec 1, 2008 | 05:37 PM
mini845's Avatar
mini845
did you find out what happened with the codes? my car is stock and i just got all of the same codes!
Doc Pain
Mar 10, 2021 04:50 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
patsum
Sep 30, 2015 02:10 PM
pkillur
Sep 30, 2015 10:51 AM
Capt_bj
Sep 29, 2015 04:22 PM
