Electrical battery rating for MCS
Old May 21, 2006 | 08:22 PM
  #26
Arly's Avatar
Arly
Here is the final install pictures. It took a bit of experimenting with the optima mounting kit. Some grinding and finally a secure battery using the oem hold down.
Old May 22, 2006 | 05:35 AM
  #27
MSFITOY's Avatar
MSFITOY
Thanks for the images...what kind of grinding did you have to do specifically? It fit looks very OEM
My boy is 1/2 pure Chinese (from me) and the other half is Hines 57 (wife)
Old May 22, 2006 | 06:36 AM
  #28
Arly's Avatar
Arly
I had to grind the clips off the Ford adapters and I had to grind, using a dremel tool, the radii to match the outside cylinders of the battery. If you get the Group 78 version of the Optima Batts (800CCA versions), these adapters will fit because they are made for them. I was thinking that I should have bought the 800CCA, but I was not sure it would fit. After remeasuring, I think the 800CCA would fit.
Old May 22, 2006 | 06:46 AM
  #29
MSFITOY's Avatar
MSFITOY
Is the 800CCA bigger than OEM? Does Autozone carry this one too? Thanks
Old May 22, 2006 | 10:43 AM
  #30
Arly's Avatar
Arly
They do. Look at the optima website. They should have dimensions. The height dimension includes the posts.
Here is the link:
http://www.ibsa.com/www_2001/content...autosealed.asp
If you have a Batteries plus they off them too at a slightly higher price, but they sure know what they are talking about. Plus they have the universal optima adapter brackets like I mentioned.
Carl
Old May 22, 2006 | 10:50 AM
  #31
MSFITOY's Avatar
MSFITOY
Here is the link:
Carl
Just to double check...the correct part number for this is SC34U?
Old May 22, 2006 | 12:12 PM
  #32
Arly's Avatar
Arly
SC34U is for the 78 series for the bigger Red Top. This is not a deep cycle batt. If you run a big stereo and such, get the Yellow Top Deep Cycle. From the chart, it should be the one with part numbers SC51DA or SC51RDA.
Otherwise you might be able to fit the commercial grade SC75DU. This will be a yellow top I would assume.
The one I used was a SC75U Red Top. This is a common batt at ordinary autoparts stores.
Old May 22, 2006 | 12:13 PM
  #33
Arly's Avatar
Arly
Sid,
Measure your OE batt and include the height of the terminals post. That is how optima measures for height.
Carl
Old May 26, 2006 | 03:22 AM
  #34
jody's Avatar
jody
Why not coat the battery compartment with a layer of the spray in truck bed liner?
Old May 26, 2006 | 11:18 AM
  #35
Arly's Avatar
Arly
Why coat it? It's rarely seen? Unless I am missing something.
Old May 26, 2006 | 02:21 PM
  #36
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The coating might help prevent damage by spilled electrolyte, but in the case of batteries such as the Optima or Braille, there is no free liquid electrolyte to spill. These are AGM (absorbed glass mat) batteries that have all their electrolyte 'soaked into' the plate separators like a sponge. The stock battery uses a conventional liquid electrolyte, but the vent has a tube attached to it and exits outside of the car.
Old May 26, 2006 | 03:00 PM
  #37
Arly's Avatar
Arly
That makes sense. I forgot about why, but since I got a ge batt I was not worried about spillage. has anyone tried to do a quick disconnect? I bought one thinking I could fit it but it make the terminal too tall and I could not close the top cover of the boot.
Old Jun 3, 2006 | 06:11 AM
  #38
MSFITOY's Avatar
MSFITOY
Hey Carl...cute picture
Got the Odyssy Yellow Top installed last night and jammed away in the garage I accidentally left power on to a bank of gauges all night and found the battery was still in the high 12v this morning
I didn't have to modify anything other than the factory bracket was notched 3/4" higher for the taller OEM battery so I put in a hard foam spacer between the bracket and the top of the new battery...thanks for all your inputs
Sid
Old Jun 3, 2006 | 12:01 PM
  #39
bgrpph's Avatar
bgrpph
I bought a red top Optima 75/35 at Costco few months back as PM as car was over 3.5 yrs old- I forget the costco # ( i can look it up if anyone needs it) but looking in their store booklett shows it fit grp 47 size. It fit w/o any mods and has been doing good.
Old Jun 13, 2006 | 08:51 AM
  #40
mtnbkr's Avatar
mtnbkr
Aloha,
Please, if you can post the costco number that would help. My battery is dead and the car has low miles so no dealer help.
J
stevepsd
35
Dec 6, 2022 03:22 PM
theateist
Aug 17, 2019 01:38 AM
eatsleepautox
Oct 30, 2015 06:46 AM
bansasn
15
Sep 4, 2015 01:24 PM
Getrieben
Aug 15, 2015 09:09 PM
