Electrical Where to tap Power?
Old May 4, 2006 | 07:29 AM
Arty13's Avatar
Arty13
Where to tap Power?
I will be adding a usb hub, usb 3.5 harddrive, and a Liliput Touchscreen to the front of my MCS '06. Where would be the best place to power all these devices behind the dash? I will also need to power a M2-ATX car power supply for my MINI-ITX pc, which will probably be mounted under the passenger seat, there will also be a amp for a sub under the drivers seat. I know the amp will go straight to the battery, but everything else, i do not know where to power them from yet.
Any Ideas would be great!
Old May 6, 2006 | 11:04 PM
Wonderdrug's Avatar
Wonderdrug
Get your hands on a Littlefuse Add-a-Circuit and tap power
right from your fusebox. I did some searching (I'm in the process
of hard-wiring my iPod and a radar detector) and this looks
like the easiest way to get power and have it protected.
Old May 7, 2006 | 09:55 AM
Arty13's Avatar
Arty13
Would one circuit be enough to power 4 things? or would i have to get more than one circuit?
Old May 7, 2006 | 11:41 AM
Wonderdrug's Avatar
Wonderdrug
If you do not mind sharing a single fuse, then you should
be able to wire it for four devices, as long as the total draw
is no more than 10A. I personally got two of them, just to
be on the safe side (they are not too expensive... about $6
and that includes four fuses). The most difficult part for me
was finding out which fuse to piggyback off.
Old May 26, 2006 | 08:37 AM
JustJAY's Avatar
JustJAY
Depending upon the power of the amp, you may consider getting a capacitor for it. It will help in the "lights dimming" effect on hard hitting bass. Usuallly it is 1 cap per 1000 watts, but that was back in the '90's.
Old May 26, 2006 | 08:56 AM
Eric_Rowland's Avatar
Eric_Rowland
See the thread titled Looking for switched power fuse to tap in this forum for tapping locations.
If you know the power draw for all items you can might get away with one, but as Wonderdrug said, I'd use a couple just for margin of error.
Filmy
15
Jun 6, 2023 06:27 AM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
eliseo1981
Sep 30, 2015 01:53 PM
ou812_tugger
Sep 5, 2015 03:24 PM
Ntety
Sep 2, 2015 08:39 PM
