Electrical Horn wiring - connector question
Old Feb 18, 2006 | 10:33 AM
rclements's Avatar
rclements
Greetings --
I am a novice when it comes to car electrical systems ...
Does anyone know the specifics of the factory horn electrical connectors?
I see one multi-colored wire and one brown wire [presumed to be ground].
Is the multi-colored wire a single hot line, or is it a pair of leads in a single wire? I don't want to cut it without knowing what's in there ...
Why, you ask?
I am pondering splicing into one of the existing horn connectors and adding a third horn to the mix [ low tone] for more volume.
I don't really want to go the air horn route, and I don't really want to tear the front bumper off the car again.
Does anyone have any sage advise?
thanks!
RobsSilverMINI
Old Feb 18, 2006 | 10:39 AM
Uncle_John's Avatar
Uncle_John
Poke a pin into the one that you think is power, Hook a volt metrer to it and beep the horn. If you get a 12v reading, that will confirm that its power. If you don't want to cut the wire, use a scotch-lock splice.
Old Feb 18, 2006 | 02:44 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Brown is the standard color for a ground wire on a MINI, so if you see a solid brown wire attached somewhere or inside of a connector, it's a ground.
Old Feb 18, 2006 | 05:06 PM
rclements's Avatar
rclements
Best place to pull +12V?
I got a relay, a +12V ps and some swtiches from a local car store. I think I have it figured out now!
I have a spot picked out and I believe I understand how to wire up a relay to switch the new horn.
What's the best [easiest] place to hook into +12V ? Alternator? Battery positive terminal under the hood ? Fusebox?
thanks!
robc
Old Feb 18, 2006 | 05:58 PM
Uncle_John's Avatar
Uncle_John
I used the battery post under the hood. Don't forget an inline fuse . . .
Sounds like you have it whipped!
Old Feb 19, 2006 | 05:38 PM
rclements's Avatar
rclements
Add a horn - Project Compete, Honks alot.
Howdy,
Thanks to the assistance of Uncle John And Greatbear, I got a third (!) horn installed in the passenger-side cowl. It's main benefit is that it is LOUD at 138 DB. I chose a Carrand "Margum Blaster" electric horn with a low tone roughly one octave below the MINI's regular low horn. Cost was <$20.00.
I added a 30A relay switched by a jumper wire tied to the existing passenger-side horn positive ( "non-brown") lead and dressed in the cables through the existing grommet at the bottom of the pass. side cowl box. See pic attached.
Uncle John recommended a fuse, and I had already decided I wanted one based on a discussion about foglights I read somewhere. Anyway I put an spade-stype fuse holder inline between the relay and the battery feed. I used a 25A fuse to protect the 30A relay.
I found some very handy add-a-connector plates at my auto store. They basically slip under your existing battery terminal [ or ground screw] bolt and provide you with three male spade connectors compatible with most crimp-on spade connectors. This made tapping the ground screw and battery jump terminal under the hood relatively easy, and I have two open pos/neg attach points left for future use. Very handy, and cheap.
Lastly I fabricated a mounting bracket for the new horn by bending one of the provided straight plates into a right-angle and adding a slight twist to enable the horn to sit nicely in the inside corner of the cowl vent, just under the vent cover. See pics attached. I did have to drill one hole in the pass. side cowl box to provide a hole through which I fastened one end of the bracket. The horn is light enough that a simple 10mm nut and lock-washer on the chassis side of the bracket suspend it firmly in the cowl opening without need any other support. It basically hovers in the right spot. : )
I made all connections and tested everything first, then firnished off by enclosing the relay and crimp-on connectors in a waterproof box, which I attached to the firewall with some 2x4" velcro strips. See pic attached. In fact this was a camper's soap carrier, cost me about $1.00. : )
End result: Three horns, great volume. The low tones are more like a 7th apart than an octave, so it has a dissonance that works well for getting attention.
The Best Part: Sonce all the wiring is done, so I can switch out the horn itself for another model with very little work.
Old Mar 5, 2006 | 02:44 PM
rclements's Avatar
rclements
FYI replaced Carrand with a Stebel Nautilus
lounder and cooler!!
Wohnson89
Jun 10, 2020 04:53 AM
one73ronin
Aug 19, 2015 12:36 PM
Super Coop
Aug 17, 2015 05:09 PM
PSIChocolate
Aug 13, 2015 12:46 PM
