Electrical RPM source for RPM sensitive lighting
Old Jul 18, 2005 | 07:51 PM
wannaminis's Avatar
wannaminis
OK, so I got my 05 Cooper S. Now I want to do things to it! Besides the SC pulley, Alta cold air intake, etc. etc. I want to install under-vehicle lighting (StreetGlow) which has the option of RPM sensitivity; higher RPM means brighter glow. Problem, you can't get the RPM signal from the coil cause there's not one. Has someone else tackled this before or am I possibly having an original thought .
Old Jul 19, 2005 | 04:56 AM
Profpatpending's Avatar
Profpatpending
What do you mean theres not one there are two
one for each pair of cylinders but the signals are not very clean so you will need a filter if you want to go that route or else tap a cable at the ECU for one of the injectors if you want a cleaner RPM signal
Old Jul 20, 2005 | 06:57 AM
wannaminis's Avatar
wannaminis
RPM signal source
Thanks for your feed back, Prof. You're correct; there is a coil pack. You mention filtering the signal. Just how is this accomplished? Is this an aftermarket item? Tapping the ECU as a source leaves me concerned about the potential to cook the ECU or degrade the performance of the downstream component. anyhow thanks for your response.
Old Jul 20, 2005 | 11:37 AM
Profpatpending
yeah I tried searching all the vendors but no luck, I know one of them sells a filter that connects to the coil pack and gives you a nice clean signal for use with a shiftlight, this would work perfectly if I could only remember who sells it,
Old Jul 20, 2005 | 07:13 PM
wannaminis's Avatar
wannaminis
RPM Sensitive Lighting
Thanks for the tip, Prof. OK, in a JEGS catalog I found an item referred to as a "tach adapter". Says you can connect a tach, shift lite, or RPM switch to a DIS system. What's a DIS system? Also says this adapter converts information into a 12V square-wave signal and wires easily inlineon the coil positive 12V wire. Unit is made by AutoMeter. Is this what you're talking about? If so, I quess a volt-ohm meter is all I need to find this 12V wire feeding the coil pack. What do you think?
Old Jul 20, 2005 | 07:59 PM
namwob's Avatar
namwob
DIS Distributorless ignition system (thats you)
Old Jul 21, 2005 | 12:35 AM
Profpatpending
http://store.summitracing.com/defaul...h.asp&N=400442
here we go I found it,
this is the baby you want
type in this part number MSD-8913
Old Jul 27, 2005 | 07:36 PM
04yellowS's Avatar
04yellowS
I thought Pilo had one, but I can't find it on their website. I thought it was cheaper than the MSD item also.
stellaherself
Aug 14, 2015 05:28 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
