Electrical adding auxiliary power outlet
Old Jul 5, 2005 | 06:32 PM
Call's Avatar
Call
I wanted to add a power outlet in the euro shelf area and thought I could use an add-a-circuit. My present power outlet is on row 2 #32 which is 15 amp. Add-a-circuit is limited to 10 amps. What am I missing here?
Old Jul 5, 2005 | 09:40 PM
Rich.Wolfson's Avatar
Rich.Wolfson
If you use the aux outlet to power or charge things you'll be fine. VERY few things besides the cig lighter will draw anything close to 15 Amps. If you're not planning on plugging a heater or power tool (not to charge but to power) in there you'll be well within 10 amps.
Old Jul 6, 2005 | 04:29 AM
Call's Avatar
Call
So, where can I connect...anywhere a 10 amp circuit is located?
Old Jul 6, 2005 | 04:06 PM
Rich.Wolfson
<<So, where can I connect...anywhere a 10 amp circuit is located?>>
Not really. Depending on what you will power you either want it switched (goes on when the key is in positon 2 or running) or unswitched. I am not near a manual right now but there is a legend inside the cover of the fuse panel that may be of some help. The good thing about the Add-A-Fuse is that it is a simple matter to change it if you pick the worng one.
Old Jul 7, 2005 | 12:43 PM
bomboasy's Avatar
bomboasy
I also have the Euro Tray, but because the plugs of my radar detector and G-Force computer have functions on them, I did not wanted to place them out of sight. This is what I came up with, in case it might be helpful to you:
https://www.northamericanmotoring.co...ad.php?t=45620
Bomboasy
Old Jul 7, 2005 | 12:49 PM
mbabischkin's Avatar
mbabischkin
One thing you'll find is that at least on the '05s there are no switched 10 amp circuits. You'll need to use a 5 amp circuit if you want switched power. I've got mine connected to F10
Old Jul 10, 2005 | 08:28 AM
Call's Avatar
Call
Perfect. That works just fine. Thank you, people.
Don't you just love it when things come together
tylewis
Sep 6, 2015 01:07 PM
ou812_tugger
Sep 5, 2015 03:24 PM
jesterofatlas
Sep 4, 2015 11:23 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
Ntety
Sep 2, 2015 08:39 PM
