Electrical OBDII Cables on the cheap!
Old May 8, 2005 | 04:37 PM
tradiuz's Avatar
tradiuz
MTH Specialist
Since I'm so tight that I squeak when I walk, I thought I would share some cheap ways to make your own OBD-II cable for use with OBDII scan software and hopefully MTH (My primary reason for making it).
I'll post my results within a week or two when I solder it all together, but if it works... no more spending $100+ on $30 worth of parts.
http://www.planetfall.com/%7Ejeff/obdii/
Thats the link to the schematics, and parts needed.
Old May 8, 2005 | 05:26 PM
minimonkey's Avatar
minimonkey
Hmmm, that is VERY interesting. Too bad I already bought my cable - or I would have tried it. For anyone with basic electronic skills, it looks easy to make. Alot of folks might not have the skills to tackle it. Good luck with it!
Old May 8, 2005 | 05:58 PM
kaelaria's Avatar
kaelaria
More useful would be a schematic for a USB cable. The days of serial are are gone.
Old May 8, 2005 | 06:16 PM
tradiuz's Avatar
tradiuz
MTH Specialist
USB is alot more difficult seeing as you'd need a USB->Serial controller chip and driver software.
The OBDII port is natively a 9600 baud serial connection, for which classic style serial ports are the perfect solution.
Old May 8, 2005 | 06:46 PM
kaelaria's Avatar
kaelaria
That's my point - laptops haven't been made with a serial port in 4+ years.
Old May 8, 2005 | 07:32 PM
tradiuz's Avatar
tradiuz
MTH Specialist
They just need to make ODB-3 a USB2.0 compatible connector, and flashing/detecting would be a ton faster (near instantaneously compared to 6+ minutes for a 60k file)
Old May 8, 2005 | 08:59 PM
kaelaria's Avatar
kaelaria
That certainly would be ideal!
Old May 9, 2005 | 09:34 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Then it's a good think my circa 1998 Vaio laptop is still happy. Wish it had more than 1 usb port though.
Old May 9, 2005 | 11:41 AM
tradiuz's Avatar
tradiuz
MTH Specialist
http://www.mouser.com/index.cfm?hand..._pcodeid=62602
That would handle the USB -> RS232, plug that straight into the 'magic box'. Or if you were really skilled they sell a USB->UART IC for 5.70
Parts list from Mouser.com:
Part #Mfr.'s
Part #Manufacturer
Description
Your Part #Order
Qty.PriceExt.551-PS2501-1 PS2501-1NEC/CEL
DIP-4 Hi-Iso Photo 1-Ch
2501-3 IS 3 OF THESE 3 $0.24 $0.72 511-2N3904 2N3904STMicroelectronics
TO-92 NPN General Purpose
T1 & T2 2 $0.32 $0.64 833-1N4004 1N4004-TMCC
DO-41 Vr/400V Io/1A BULK
D1 & D2 2 $0.05 $0.10 291-1K 291-1KXicon
1/4WATT 1KOHMS 5%
R1,R2,R5,R6,R7,R9 10 $0.07 $0.70 291-1.5K 291-1.5KXicon
1/4WATT 1.5KOHMS 5%
R3 10 $0.07 $0.70 291-10K 291-10KXicon
1/4WATT 10KOHMS 5%
R4 10 $0.07 $0.70 291-150K 291-150KXicon
1/4WATT 150KOHMS 5%
R8 10 $0.07 $0.70 647-USR1H010MDA USR1H010MDANichicon
50V 1uF 4x7
C1 1 $0.21 $0.21 571-7478404 747840-4AMP
PLUG FRNT MTL SHL 9P
DB9-M 1 $1.15 $1.15 571-7478444 747844-4AMP
RECP FRNT MTL SHL 9P
DB9-F 1 $1.36 $1.36 501-FR4X6S 501-FR4X6S
4X6 FR4 COPPER PCB
2 $1.96 $3.92 Sub Total: $10.90
Only other thing you need is etchant, such as Ferric Chloride, a RS232 cable (I had one laying around) and the OBD2->DB9 Connector (AutoTap replacement cable $19.99 works).
Old May 9, 2005 | 12:13 PM
tradiuz's Avatar
tradiuz
MTH Specialist
http://cgi.ebay.com/ebaymotors/ws/eB...category=43989
I'm pretty sure that would work too (it costs as much as it costs to make one by hand heh). Shame I didnt see that earlier!
Old May 10, 2005 | 04:54 AM
Cooper S IRE's Avatar
Cooper S IRE
be carefull buying an OBDII connector with the elm based chip inside as it wont work with some cars and wont work with MTH trust me i know
Old May 10, 2005 | 01:07 PM
tradiuz's Avatar
tradiuz
MTH Specialist
The ELM setup seems like it should work, any definite reason that it didnt?
Old May 12, 2005 | 01:11 PM
Cooper S IRE
i dont have any definate reason why but the Elm chip wont work with MTH and only with some brands of cars
Old May 12, 2005 | 01:24 PM
tradiuz's Avatar
tradiuz
MTH Specialist
The reason I ask is because they show that their OBD-II Cable and software works with Mini Cooper 02+
Old May 12, 2005 | 01:55 PM
Cooper S IRE
yeah dont get me wrong i bought a OBDII cable with the elm chip
the software available for this setup is very basic and as i said it wont work with the MTH software
but you can read some codes from some of the modules on the car
but if you want to do this properly wait for Bim com to be released
now that will be serious diagnostic software
Old May 12, 2005 | 08:25 PM
tradiuz's Avatar
tradiuz
MTH Specialist
OK, i got the obd2 thing to work with the free software, the problem is, my neighbor backed over it before i could try MTH
Old Aug 21, 2005 | 08:44 PM
guru220's Avatar
guru220
i am getting confused about this cable issue. i think its just me tho. i have a sensolutions mono-com cable for my MTH software and thats working fine.
I then wanted to get the Auterra Dyno-Scan software but noticed that its $239 for software and their cable or $99 for just the software... i have a cable so does that mean i can just get the software alone. I emailed them and told them what i had and they just told me i need to buy the whole package, is this true or are they just trying to make more $ off of me? is an obdII cable just an obdII cable or is theirs special and different?
http://www.auterraweb.com/index.html
Old Aug 22, 2005 | 12:05 AM
Profpatpending's Avatar
Profpatpending
most obdII manufacturers build in a dongle into their cables so their software will only work with their cable,
I bought a generic cable and none of the software I downloaded worked with it.
Old Aug 22, 2005 | 07:42 AM
guru220's Avatar
guru220
is there any way around that?
Old Aug 22, 2005 | 11:35 AM
Profpatpending
not that I found,
unless you can decompile and remove the software interlocks in the programmes,
if you do let us know
Old Aug 25, 2005 | 08:24 PM
MadHatter's Avatar
MadHatter
or Ammonium perchlorate for etching the PCB
a little tricker to work with than ferric choloride, but much more green for the environment. Althought it won't clear your plumming pipes :smile:
Old Sep 3, 2005 | 06:16 AM
1FSTMINI's Avatar
1FSTMINI
So im seeing that theres a chance there are certains cables out there that wont work with the MTH system?
I use a OBDII-USB cable to d/l my Dinan software which i was going to use with the MTH files but im now worried it will not work after reading all these posts.
Old Sep 3, 2005 | 06:27 AM
MGear's Avatar
MGear
Give you guys a chance and you all can make a mountain out of a mole hill. This thread is about as clear as flight path to the moon
When I asked Volker what cable to get this is what he said:
"MONO USB is the one."
Whatever the heck you have written above makes no sense and in this particular case looking for the cheap way out will wind up being the most costly in the end.
And you can get it from:
http://www.sensolutions.com/product....php?category=1
Old Sep 3, 2005 | 07:10 AM
1FSTMINI's Avatar
1FSTMINI
I use a Unitronic OBDI-OBDII adapter with Dinan seriel port connector ( OBD-USB ) to do software flashs here.....Im just concerned that its there own set up and it wont work like everyone is stating with other cables. My best bet is to try uploading it onto Cartunes and see if it works i guess.
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
Winston46
Nov 9, 2015 06:18 AM
ahorvath
Oct 3, 2015 01:13 AM
MINI Stupor
Oct 1, 2015 11:36 AM
