Electrical Ok to bypass lighting wiring harness?
Old May 4, 2024 | 12:29 PM
Phishisgr8's Avatar
Phishisgr8
I picked up a set of plug-and-play Halogen > LED headlamp assemblies.
Installation went easily enough on one side, but the other side is giving issues.
The harnesses the light manufacturer supplied are dog crap. They just don’t want to line up with the OEM sides at all, and some pins have been bent as a result of me pushing the harnesses together as hard as I can like an idiot.
What is stopping me from just snipping the harnesses off and connecting the wires from each end directly, using something like bullet connectors? (Besides ease of disassembly and reassembly, that is.) Do these harnesses do anything besides connect wire A to wire B, and C to D?
Old May 5, 2024 | 04:21 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Nothing wrong with snipping connectors, other than ease of assembly and disassembly. However, you might want to consider a set of automotive style connectors with gaskets. Otherwise, water can get in and start to cause corrosion of the pins, leading to intermittent failures.
Old May 5, 2024 | 11:15 AM
Phishisgr8's Avatar
Phishisgr8
Thanks a bunch, NJA. I ended up splicing the wires using solder seal connectors, and the lights are working great. Hooray.
I appreciate your chiming in!
jk6672
Electrical
Sep 27, 2021 11:02 PM
ED955S
Jun 15, 2010 01:52 PM
british RACING green
Jan 30, 2009 06:47 PM
cory4281
Classic Mini Talk
12
Apr 21, 2007 11:19 AM
