Electrical GM Central Locking fuse?
Having just performed a routine scan with my Foxwell N 510 elite OBDII - I came across a fault reading in regards (to the posted title): "GM - Central Locking fuse"
I should note: My driver's door hasn't worked in years unlocking with the key fob but will lock with the fob (works fine unlocking/locking the passenger & hatch). The toggle panel locking switch only locks and unlocks the passenger & hatch but not the driver's door either.
So it seems rather strange that after all these years this "Central Locking fuse" fault should have now just popped up.
I have checked the 20A cabin fuse F37 and it looks fine. I also checked the 50A FL7 fuse under the hood and it also appears to be fine.
Are there any other fuses to look for that relate to the central locking system that I may have missed??
I should also note: my BCM has never had any water intrusion.
It would sure be nice if after all these years (even after replacing the driver door actuator) that a simply blown fuse may get my driver door locking/unlocking again.
Thanks in advance.
Thanks in advance.
alpalpha
May 17, 2015 11:16 PM
