Electrical Driving light install
Old Jun 30, 2019 | 11:50 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I'm installing led driving lights, using a relay and switch to enable them. Iwould like to only have them turn on when the high beams are on, the car has hid lights and the relay is located in the abs area.
Anyone know what wire the hid uses when on? I can use that to trigger the relay
Old Jun 30, 2019 | 12:43 PM
Eric_Rowland's Avatar
Eric_Rowland
OEM install taps in to the wire by the BCM/BC1 (passenger footwell.)
29. Connect wire to the yellow/green wire going to X322 pin 15 of BC1
It's a pain to get to, and there's not much room, but easy enough to identify.
Old Jun 30, 2019 | 01:53 PM
MrBlah's Avatar
MrBlah
I saw that, long way from my relay, I would prefer to avoid that
Old Jul 1, 2019 | 11:53 AM
Eric_Rowland
Yeah, it's a wire run across the dash, but that's what the Germans recommend.
Old Jul 1, 2019 | 02:18 PM
Capt_bj's Avatar
Capt_bj
that's the factory set up .. run a wire all the way across ........
wiring diagrams I have are not clear as to where you could tap a line at the light fixture ....... not clear to ME anyway . . .
Old Jul 3, 2019 | 02:49 PM
veedubpat's Avatar
veedubpat
If wiring must be tapped in the engine bay, use a test light to determine which circuit has power while the high beams are on, and no power whilst off.
Doing it the correct way (as Eric_Rowland has mentioned) is always an option, however.
Old Sep 25, 2019 | 05:17 AM
MrBlah's Avatar
MrBlah
the "german" way is not happening, will be testing wires tonight I have the lights installed with a double relay, just need to find a trigger for the 2nd relay off the high beams
JustDanD
Sep 24, 2012 02:29 PM
milesthng
Oct 19, 2011 08:36 PM
jbing
How to
77
Jul 6, 2011 08:18 PM
punkjazz
Mar 20, 2004 03:50 PM
wjklos
28
Jan 24, 2003 09:59 AM
