Electrical Brighter LED DRL bulbs for Spyder headlights?
Old May 20, 2019 | 01:00 AM
myleshailey's Avatar
myleshailey
picked up the spyder “F56 style” projector headlights for my ‘13 MCS a couple months ago and i love them so far. however, the DRL LED’s in the headlights are very low-powered and are almost unnoticeable in daylight. has anyone open the headlight and attempted to replace the internal LED’s for the DRL for brighter one’s?
Old Jun 20, 2019 | 12:33 PM
Yupetc's Avatar
Yupetc
Get Carly and code the brightness level.
Old Jun 21, 2019 | 04:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Carly app will have no effect on aftermarket DRLs...
There was a user here that opened his up, but can’t remember who it was...
Old Jun 21, 2019 | 07:24 AM
Yupetc's Avatar
Yupetc
I hadn't even thought about that. Then here's what I'm suspecting:
The LED's if the OP installs it following the instructions, he must have tapped it to the DRL's which is the low power side of that fog light plug. If he were to switch to the fog light side, he'll get the high wattage, which in turn makes the LED's much brighter. Of course by doing this, he will then need to go to the coding menu and set the Fog lights as the DRL's. And even after that, if he's got the annoying yellow fog lights, he'll need to replace those with 6000k white foglights, or just somehow disable that fog light for good yet keep the circuitry functional for DRL and the LED's.
Another way is to route your own 12volt battery power into the LED circuit, and add a relay which takes the signal from DRL with a tap. That way you'll get all the current you need to brighten the LED's. I'm specifying all of this without looking into the LED's wattage and amperage requirements, so please check the specs before you do it that way you won't burn anything for not classing the electrical components correctly.
Good luck.
eebdel
R59 :: Roadster Talk (2012+)
Aug 28, 2021 09:35 AM
drewcifer12
Electrical
Feb 3, 2021 01:19 PM
Sharan Sunkara
16
May 4, 2019 07:32 AM
wikdr53
Aug 14, 2018 05:42 AM
MazMini
Jul 4, 2016 07:23 PM
