Electrical Retrofitting Additional LEDs along door
Old Sep 10, 2016 | 06:10 PM
AlphaQuad's Avatar
AlphaQuad
Just did the retrofit of the additional LED lighting that comes with the MINI Yours interior packages, as long as your car has the Lights Package option 563 and the MINI Excitement Pacakge option 4V9 this retrofit is possible as the wiring for the additional LEDs are already there. I believe all F56's up to MY2016 have the wiring already there.
Behind door panel
Behind door panel
Unused connector
Taped up, unused connector
Finished !
Old Sep 10, 2016 | 06:16 PM
pepsih's Avatar
pepsih
amazing i want to do the same
Old Sep 10, 2016 | 06:18 PM
AlphaQuad's Avatar
AlphaQuad
I'll be happy to post the part numbers and what is required later, but it requires drilling out the old plastic rivets which hold the old trim to the door. So not for the faint hearted!
Old Sep 10, 2016 | 11:45 PM
hammerhands's Avatar
hammerhands
What lights up?
Old Sep 11, 2016 | 05:04 AM
pepsih's Avatar
pepsih
I'm ready for that
however I'm wondering how did you find the LED itself because I checked REALOEM and looks like I have to get the right trim
http://www.realoem.com/bmw/enUS/show...diagId=51_1157
part 12 and 13 from the yours package but i don't see the LED itself.
cant wait to see how you did that
Old Sep 11, 2016 | 08:34 AM
AlphaQuad's Avatar
AlphaQuad
I'm ready for that
No, you are correct you do need to buy the whole trim that includes the LED light guides. The old trim is not reused. The LED's are a separate module also.
Old Sep 11, 2016 | 03:26 PM
pepsih's Avatar
pepsih
Coding required or pnp? please give us more info
Old Sep 11, 2016 | 06:34 PM
AlphaQuad's Avatar
AlphaQuad
PNP for cars that have Lights Package 563 and MINI Excitement Package 4V9, as stated in the first post I think all f56 sold in the NA had those two options between MY2014-2016
Old Sep 12, 2016 | 11:40 AM
AlphaQuad's Avatar
AlphaQuad
Here are the part numbers for both the F56 and F55
TRIM:
F56 3 DOOR, PIANO BLACK
51417410581 - 51417410582 - 51417410587 - 51417410588
F56 3 DOOR, DARK SILVER
51417410583 - 51417410584 - 51417410589 - 51417410590
F56 3 DOOR, OFF WHITE
51417410585 - 51417410586 - 51417410591 - 51417410592
F55 5 DOORS, PIANO BLACK
51417414219 - 51417414220 - 51417414225 - 51417414226 - 51427414233 - 51427414234
F55 5 DOOR, DARK SILVER
51417414223 - 51417414224 - 51417414229 - 51417414230 - 51417414237 - 51417414238
F55 5 DOOR, OFF WHITE
51417414221 - 51417414222 - 51417414227 - 51417414228 - 51427414235 - 51427414236
LED module: 63319263454
for the F56 you will need a qty of 4
for the F55 you will need a qty of 6
also you will need the securing washers to attach the new trim pieces to the door card unless you want to epoxy them back on. I only have the quantity required for the f56 which is a total of 50 pcs.
The part number is 51412756689.
Hope this helps guys!
arunka007
Aug 21, 2016 12:47 PM
TJANK
Aug 18, 2016 02:55 AM
alexinvancouver
Vancouver Mini Cooper Club
Aug 16, 2016 02:32 PM
Fishbreath
Aug 16, 2016 12:38 PM
TJANK
Aug 15, 2016 11:28 AM
