Electrical Accessing the Canbus twisted pair
Old May 14, 2016 | 05:22 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
anyone done any experimenting on the canbus on our r53's?
I'm getting terrible speed from the kline on my 2005 r53, 1hz update rate! The canbus is much faster but I'm not sure if bmw implemented standards onto it, ie hook it up to an odb female port and read from there.
I know some of the race logging setups can read it once they are tapped into it, not sure if it supports standard connections once pins 6 & 14 are hooked up
Old May 16, 2016 | 03:36 AM
chris.j.lamb's Avatar
chris.j.lamb
Usual access is between the centre instrument pack & the column mounted instrument pack under the column pack.
check this :- http://tucrrc.utulsa.edu/CANClock/DE...aggs_Paper.pdf
Cheers
Old May 16, 2016 | 04:25 AM
MrBlah's Avatar
MrBlah
Getting to the wires is easy
Old May 19, 2016 | 05:34 AM
MrBlah's Avatar
MrBlah
making progress, somoene on the bimmer forum made a canbus to arduino to elm327 bluetooth setup that reads the bluetooth requests and sends them to the canbus and then sends the replies back
that's exactly what we need to make the data loggers speed up, 1 update a second is far too slow to be of any use off kline
Old May 19, 2016 | 09:33 AM
rkw's Avatar
rkw
If it's a speed signal you want, it's available on a separate wire. See the instructions here:
http://www.fes-auto.com/upload/doc/4...er%20Guide.pdf.
Old May 19, 2016 | 01:51 PM
MrBlah's Avatar
MrBlah
It's not I need throttle rpm and map if these have one
And the software needs it off an elm327 Bluetooth adapter
HaveATank
361
Jan 23, 2017 03:10 PM
sir5150
May 23, 2016 10:33 AM
darex
May 16, 2016 08:53 AM
MiniTigger
31
Apr 29, 2016 11:19 PM
BradStepsMini
Apr 19, 2016 06:38 AM
