Electrical Misfire
Old Feb 23, 2015 | 04:57 AM
sbninja's Avatar
sbninja
Misfire
Driving in to work this morning. Stepped on te gas a bit, meth started spraying , then rough idle. I little while later , the check engine light came in.
I pulled over and read the code - cylinder 4 misfire.
I was closer to work than home, so I continued to work.
I hope it's just the plug:(
Old Feb 23, 2015 | 08:33 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Bad coil maybe? Swap a coil from different location and see if the code follows the suspected bad coil to new cyl location.
Old Feb 23, 2015 | 02:16 PM
sbninja's Avatar
sbninja
I switched #4 coil with #1 coil. Now reading code multiple random cylinder misfire and cylinder 1 misfire.I pulled the suspect bad coil while engine running , no change. Pulled one of the other coils and engine started running worse. At the dealer now picking up a new coil. Sent from my iPhone using NAMotoring
Old Feb 23, 2015 | 02:23 PM
sbninja's Avatar
sbninja
Ok, just swapped it out in the parking lot. All is well!
Thank you
Old Feb 23, 2015 | 02:58 PM
minirab's Avatar
minirab
Had the same thing happen to me.
Old Feb 23, 2015 | 03:21 PM
sub3622's Avatar
sub3622
i have been fighting this multiple combustion misfires for a while.
CEL is on with the following codes:
DME
2783 combustion misfires several cyl.
277B combustion misfires several cyl.
277F combustion misfires several cyl.
2773 combustion misfires several cyl.
2DCA fuel shutoff due to super knocking cyl. 4
2DCB
2DCC
2D52
Can anyone point me in the right direction? i need help
I´ve been reading a lots of threads about this but non of them tells me what is exactly the problem
Old Feb 23, 2015 | 03:37 PM
-=gRaY rAvEn=-
Moderator
Thank you
Fordgt4
Oct 10, 2015 10:42 AM
randeez
Oct 5, 2015 09:23 AM
dutchhome
Sep 30, 2015 07:17 AM
silence2-38554
Sep 28, 2015 12:19 PM
ShadyCoop
Sep 20, 2015 08:57 AM
