Electrical Rear fogs wiring questions
Old Jan 23, 2015 | 04:55 AM
Bingote's Avatar
Bingote
I have the rear fog lights connected to their harness to work as that, fog lights... But I want to make them work as brake lights when fogs not in use. There's this "add a brake light" kit (basically wires to tap to the brake lights) that i'm planning to use.
Question is: is there a problem by doing this? Will i create some kind of loop or a condition where i can damage something if i send power when braking to the already conected fog lights wiring? Thank you!
Edit: I have a R57S 2009
Old Jan 25, 2015 | 11:21 AM
ammodave's Avatar
ammodave
If you're worried about feedback between the rear fogs and brake lights, just add a diode into the voltage feed wire for both systems. They'll act as a "one way valves" and prevent feedback.
Old Jan 25, 2015 | 06:55 PM
Bingote's Avatar
Bingote
The kit to make them work as brake lights comes with diodes, so I'm guessing I should add my own diodes to the stock fog lights voltage?
Thank you!
Old Jan 26, 2015 | 08:26 AM
ammodave's Avatar
ammodave
I'm not familiar with the kit you're referring to but you need at least 2 diodes: one between the fogs and the oem input voltage for the fogs and a separate diode between the fogs and the brake light voltage input.
Old Jan 26, 2015 | 09:17 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
This kit we have left over from when they use to make them already has the diodes in them.
http://waymotorworks.com/gmg-give-me...light-kit.html
Old Jan 26, 2015 | 10:03 AM
Bingote's Avatar
Bingote
Thank you, I'll go with way motor kit, as it describes exactly what I need.
Originally Posted by WayMotorWorks
This kit we have left over from when they use to make them already has the diodes in them. http://waymotorworks.com/gmg-give-me...light-kit.html
Thank you, I'll place an order right now.
Old Jan 26, 2015 | 10:40 AM
Bingote's Avatar
Bingote
Order placed, thank you!
Old Jan 26, 2015 | 05:46 PM
Bingote's Avatar
Bingote
Hello, just sent you a private message because my order was declined and i want to know why... Thnx
Dec 23, 2015 10:36 AM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
