Electrical Countryman 25w Xenon Upgrade For R60/R62
Old May 14, 2016 | 10:59 AM
  #76
axsys's Avatar
axsys
There is a single line in NCS Expert you have to switch to active and the high beams should work. Unfortunately I'm traveling this weekend and don't have access to my coding laptop. I will dive into it early next week and see if I can find out which option it was for you.
Old May 17, 2016 | 05:54 AM
  #77
+1 i bet it was a coding iine error mistake
Old Dec 12, 2016 | 01:59 PM
  #78
Just want to give you guys a heads up. We now have halogen => projector LED DRL headlights from spyder. These are in the F60 design for your R60/ R61. They are just like the halogen spyder ones fro the R56-R59 but these are for the R60 Countryman / R61Paceman. No Xenon to Xenon version yet.
But these take halogen H9 bulbs ( or if you want to do your own xenon/ led retrofit H9) Bi-halogen. This means they have 1 bulbs that has a flap like the Xenon factory system and when you use the highs, the flap moves up.
Bottom turn signal is standard P21 bulbs and this system is plug and play.
Sold as a Set:
PRO-YD-MCO11-DRL-BK **now we have Sonar direct for a lower price. Same as spyder.
https://www.ecstuning.com/Search/SiteSearch/ES3188142/
Old Dec 12, 2016 | 03:37 PM
  #79
808keith's Avatar
808keith
Pics on a Countryman?
Old Dec 13, 2016 | 05:14 AM
  #80
No pics yet, these just came out, we are the first to have them. Should have some pics in the next couple weeks. Pretty much a F60 styled design for you R60/R61.
Old Dec 13, 2016 | 01:59 PM
  #81
ke3ee's Avatar
ke3ee
So these are projector lens but take H9 halogen bulbs? Are the lens\reflectors for Halogen or LED ?
Old Dec 13, 2016 | 02:03 PM
  #82
Projectors and for any stock H9 fitment bulbs. People use the spyder ones like the R55-R59 ( https://www.northamericanmotoring.co...adlight-2.html) or ( https://www.northamericanmotoring.co...-mini-r56.html) ones in halogen form and buy an aftermarket H9 xenon or LED retrofit kit and install them. We sell the H9 halogen bulbs, but we dont carry the retrofits for H9 bulbs in xenon / led.
Edit* we have now H9 LED bulbs here. They are not Canbus so you will have to code out the system so you will not get a bulb out error on the dash.
https://www.ecstuning.com/Search/SiteSearch/h9_led/
Old Jan 2, 2017 | 10:44 AM
  #83
voicekiller's Avatar
voicekiller
I've just done the swap and I'm taking it to get it coded at the dealership tomorrow. Dead easy install.
Quick question, I didn't see a tube to connect the headlight washer, is there any way to make these functional after the mod?
Thanks,
Chris
Old Jan 27, 2017 | 03:33 PM
  #84
Jwanck11's Avatar
Jwanck11
Why would you want to put a halogen bulb in a projector? Having retrofitted before, that would be like starting a fire with $100.00. There is no point other than wanting to have your lights look as if they are HID. Am I missing something here?
Also, Is the price on the ECS site of 1500+ for the OEM 25W retros correct? It seems there has been significant inflation. I found them for 1100 on WMW and that was just a cursory search. Maybe I am looking at the wrong product page.
Lastly, I am wondering what the OEM 35W lights would need to be retrofitted. If they have a ballast / ignitor, wouldn't a harness be the missing piece?
I definitely want to upgrade my kid's lights on his '12 R60, but will be smart about it all the same.
Old Feb 1, 2017 | 12:55 PM
  #85
techgearpro's Avatar
techgearpro
I have a pair of the Spyder halo headlights that just came in this week. I was wondering if the halo is really CCFL and not LED but it does have what is labeled as an LED inverter with the ED050-A1 part number.
They also have a label on them that says "HID bulb not allowed".
Old Feb 1, 2017 | 01:41 PM
  #86
They are LED when I had seen them. Like the R56-R59 spyder style, they should have a bunch of little LEDs that the frosted plastic shield cover halo projects them look like one continuous halo.
Old Aug 15, 2017 | 10:32 AM
  #87
bratling's Avatar
bratling
Super Moderator
Just want to give you guys a heads up. We now have halogen => projector LED DRL headlights from spyder. These are in the F60 design for your R60/ R61. They are just like the halogen spyder ones fro the R56-R59 but these are for the R60 Countryman / R61Paceman. No Xenon to Xenon version yet. (…)
PRO-YD-MCO11-DRL-BK
Last night I was driving my wife's Countryman S, bringing the family home from the airport. It has the default factory halogens with the mediocre reflector design. I saw a pair of raccoons on the road too late to do much but shift the impact point from center to corner of car. No significant damage to the car but man, did that drive home how much the factory lights suck compared to the HID option or the LEDs in my F55. They've got to go.
So I went to the ECS site and there appear to be two identical projector upgrades, one Spyder one Sonar, the latter costing $150 less:
Spyder projector upgrade, $599
Sonar projector upgrade, $449.95
What's the $150 difference, aside from the chrome vs blackout options?
I really don't care about "look" and won't be adding an HID bulb. I know from past experience that a well designed projector is a light cannon even with a halogen bulb and I don't fetishize the HID blue look. I just want my wife and kids to be safer!
Thanks!
Old Aug 15, 2017 | 10:39 AM
  #88
Nothing, one brand had it first and had a set price (but they were the first ones out), then the later brand had it cheaper. Then the chrome vs blackout versions.
Old Aug 15, 2017 | 10:51 AM
  #89
bratling's Avatar
bratling
Super Moderator
Now that is a beautiful, beautiful thing. :-)
Thank you! I guess this means I'll be earning a few entries in your very nicely upgraded A3 giveaway :-)
Old Aug 15, 2017 | 10:54 AM
  #90
Welcome.
Yep, for every 50$ you spend. Good luck.
BTW did you see this: JCW Body kits on Clearance and Free shipping
https://www.northamericanmotoring.co...plus-more.html
Old Aug 15, 2017 | 11:07 AM
  #91
bratling's Avatar
bratling
Super Moderator
Welcome.
My wife's Countryman looks like this:
Countryman 25w Xenon Upgrade For R60/R62-photo560.jpg
Two kayak carriers and a bike rack with a CooperCrap Hitch. She's about function over style; to her cars are things that go and tires are round black things. Aside from that she's awesome
(Still kicking myself for missing the JCW bodywork clearance on my old R55S. On the other hand that car was a money pit anyway! 🤣)
Old Mar 20, 2018 | 12:41 PM
  #92
snwmble's Avatar
snwmble
was going to order these but wanted to confirm that these come with the ballasts, bulbs? Wasn't sure if the part numbers included all of that
Old Mar 20, 2018 | 12:43 PM
  #93
Spyder aftermarket headlights or the OEM MINI Xenon retrofit kit?
Old Mar 20, 2018 | 12:48 PM
  #94
snwmble's Avatar
snwmble
oem projectors. I have a 2015 countryman w/ halogens.
are these the right part #'s for my application?
63102289650
63102289651
Old Mar 20, 2018 | 12:51 PM
  #95
Yep, those are it, we have it in a kit. You can see in our pics what it all comes with.
https://www.ecstuning.com/Search/SiteSearch/63102289650/
Old Mar 20, 2018 | 06:51 PM
  #96
mikey_t's Avatar
mikey_t
Are the Spyders simply plug & play in a 2011 base Countryman ?
Old Mar 29, 2018 | 09:55 AM
  #97
Updated that thread here, they are plug and play and we have the Sonar direct ones now and on post #78 have an LED upgrade option.
Old Sep 7, 2018 | 06:33 PM
  #98
LARGE_TALONS's Avatar
LARGE_TALONS
2 quick (and I'm sure, easy) questions!
I have a 2014 Countryman All 4 S, and am upgrading from the halogen bulbs and assemblies that came with the car when I bought it, to Bi Xenon.
1) Do the xenon bulbs come with this kit?
2)I guess I don't have a second question.
Thank you!
This is the set I'm referring to:
"Xenon Headlight Black 25 W - Set 63102289650 & 63102289651
http://www.ecstuning.com/Search/SiteSearch/63102289650KT/ "
Old Sep 7, 2018 | 06:50 PM
  #99
snwmble's Avatar
snwmble
Yup they do. All you have to do is plug and play then have it coded. No need to buy any ballast or bulbs. I got mine from Flow Mini new for around $900 shipped fyi
Old Sep 7, 2018 | 06:53 PM
  #100
LARGE_TALONS
Thank you for the reply!
I remembered my 2nd question: How about when/if the bulb burns out? Is there an easy option for replacement bulbs?
