Electrical HID Kit install
Old Sep 3, 2014 | 12:09 PM
Jdubstyyl's Avatar
Jdubstyyl
HID Kit install
Installed an HID kit on my 2008 MCS and it is bi hi/lo but the high beams will not work and i have the hi beam out error? And suggestions? Thank you!
Old Sep 5, 2014 | 01:09 PM
ammodave's Avatar
ammodave
What kit did you buy? I have a vague recollection that some of the kits intentionally disabled the high beams.
Old Sep 14, 2014 | 12:48 PM
s0n1c's Avatar
s0n1c
Chances are the kit is only low beams and not a dual-beam kit. If that's the case, by removing the H13 bulb from the halogen housing and replacing it with the HID bulb, you have just removed the hi-beam function from your car. It will be this way, unless you do one the following:
1. Perform the factory HID/Projector retrofit -- Best option, but most expensive
2. Buy aftermarket projectors (like I did) -- Not the best option, I have Hi-beams, but I also have the hi-beam out error you mentioned. I know they work, so I just ignore it.
3. Buy a dual beam HID kit for the H13 bulb -- Not a great idea at all. Running HID's in the halogen housing is wrong for many reasons.
OR
4. Put the halogen H13 bulbs back in the housing -- Probably your best option if you don't want to spend more money.
Alkaidovich
Jan 30, 2021 01:35 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
AZN Optics
Aug 16, 2015 11:52 PM
