Electrical Software Update with ISTA/P and K+DCan cable
Old Aug 10, 2014 | 08:45 AM
SkyJumpr16's Avatar
SkyJumpr16
Title says it all....has anyone successfully used the K+DCan cable with ISTA/P to upgrade the software in their Cooper? I know my cable works ( already done some basic programming with NCSExpert).
It's one thing to pay $30 dollars to BMW to get access. But if I need the $300 Mongoose Cable or some other J2534 compatible cable, well, that's a slightly different story. Unless of course, K+DCan cables ARE J2534 compatible.
Thanks.
Old Aug 10, 2014 | 09:53 AM
Chernobyl's Avatar
Chernobyl
To clarify: are you referring to using the official BMW ISTA/P Online software tool (which, as you noted, has a subscription cost), or are you talking about using ISTA/P that you've downloaded off the net?
In the case of the former, you must use a J2534 passthru tool ($$) or ICOM ($$$). An OBD J2534 tool is not the same as the OBD K+DCan cable.
In the case of the latter, a K+DCan cable (using a cable emulator and EDIABAS+IFHSRV32 as the interface) *should* work (although I have not tried this myself yet).
I've updated the software in many of my modules using WinKFP (I've upgraded: DME, SZL, KOMBI, CAS, RAD2). Other than borking my Bluetooth Voice Control (by not realizing that it would delete the enabling FSC code - ) it has been entirely uneventful. The nice thing about doing it with WinKFP is that it is designed to upgrade individual modules; ISTA/P normally wants to upgrade the whole car (which takes hours) unless you modify/hack the software into single module mode.
IMPORTANT NOTE: regardless of which software you use, due to the time involved you MUST have a good quality power supply hooked up to the car when programming or you risk bricking modules.
Old Aug 10, 2014 | 10:46 AM
SkyJumpr16's Avatar
SkyJumpr16
I was talking about the one you download and use offline, so that's good to know. Interesting to know about the WinKFP. I'd rather not have to go thru the HOURS of upgrading the entire car at one time.
And oh yes, I've gathered that no matter what, you need to hook it up to a power supply. This ain't like programming for the sunroof mod
Thanks, much appreciated.
Old Nov 12, 2014 | 11:17 AM
erjon's Avatar
erjon
I did program my Mini One D 2009 today using ISTA/P and d+kcan cable. I did it with car running and in my car it took around 1 hour.
Old Nov 12, 2014 | 11:19 AM
erjon's Avatar
erjon
Ofcourse is better to hook up a power supply.
Old Nov 20, 2014 | 11:58 AM
erjon's Avatar
erjon
I was using ISTA-P with expert mode, in which i was able to program or code single modules.
Old Mar 25, 2016 | 12:35 PM
MiniToBe's Avatar
MiniToBe
there was a post by you where you helped someone through there bricked CAS. I have a similar scenario and was looking for some help to recover my CAS. Do you mind show me the way or links
Old Jul 12, 2016 | 10:58 AM
MiniToBe's Avatar
MiniToBe
Got it done on my own. thanks
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
ahorvath
Oct 3, 2015 01:13 AM
MINI Stupor
Oct 1, 2015 11:36 AM
Emnotek
Sep 29, 2015 07:37 AM
