Electrical LED Turn Signal Hyperflash & NCS Expert Fix
Old Jun 30, 2014 | 09:53 AM
PNWMini's Avatar
PNWMini
I've read threads that talk about adding external resistors, using higher wattage bulbs, and coding out the bulb checks when adding LED turn signals. I haven't found a thread with a solution that works 100%.
In the FRM module there are two entries, LED_BLINKER_VORNE and LED_BLINKER_HINTEN, for front and rear LED blinkers.
Has anyone tried these to see if they solve LED turn signal hyperflash without adding an external resistor? I was hoping these entries would let the FRM module handle LED bulbs ok.
Old Jun 30, 2014 | 10:00 AM
cerenkov's Avatar
cerenkov
Have you tried CANbus approved bulbs?
Old Jun 30, 2014 | 11:20 AM
PNWMini's Avatar
PNWMini
From the threads, CANBus bulbs take care of the cold/warm check errors but don't have enough resistance to avoid hyperflashing. I have seen LED bulbs claiming to be CANBus and consuming 25W like an incandescent. They *should* work.
But, as many people seem to have had issues, I'm curious if anyone solved their problems via the LED_BLINKER keywords before I start purchasing bulbs. Be nice to have a confirmed backup plan.
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
missinmyjeep
Aug 22, 2015 07:13 PM
Lschneider
Aug 21, 2015 02:21 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
skippermini
Aug 13, 2015 06:13 AM
