Electrical Barn door defroster
Old Jan 29, 2014 | 02:37 PM
satkinson2002's Avatar
satkinson2002
Barn door defroster
I have a2009 Clubman and only the drivers side window on the barn doors works. Any help would be appreciated.
Old Jan 29, 2014 | 07:40 PM
joylove's Avatar
joylove
Please try the correct forum for your MK2 mini to find the experts for that model.
Old Jan 30, 2014 | 03:28 AM
yetti96's Avatar
yetti96
While we wait for this thread to get moved. I would say pop the door panel off and check continuity through the defrost strip. Once you confirm it is not broken somewhere then test voltage at the location where it gets power (base of defroster). Compare that value to the other side. If you get no power, then follow the wire upstream, where it could wear or get broken (door hinge boot). And keep going until you find the place where something changes (another connection, or you see voltage).
Old Jan 30, 2014 | 06:57 AM
+1 , I would check the connection at the door and the tab at the window element. Possible when the door was shut hard the electrical connector came off the tab behind the trim.
Old Jan 31, 2014 | 01:03 PM
satkinson2002
thanks for the help, I will have to get to work.
USNAE2
16
Jun 17, 2022 07:17 AM
jeri534
Nov 6, 2015 01:40 PM
torpeau
Oct 8, 2015 11:10 AM
patsum
Oct 1, 2015 06:33 AM
dutchhome
Sep 30, 2015 07:17 AM
